587,833 active members*
3,826 visitors online*
    Jun 2007
    394
    Software Crashes
    We have been experiencing multiple crashes of SW when trying to modify toolpaths with V3 add in.
    1. Create all geometry without fault/no crashes
    2. Create stock in V3 - no crashes
    3. Modify stock in V3 - no crashes
    4. Create toolpath - no crashes
    5. Edit the geometry selection and press OK - frequent crashes
    PC is Dell XPS which has 7 GB ram 64 bit quad core. Do I need more RAM? Re-Install software?
    If you click geometry before window appears which states that geometry may have been modified will this cause a crash?
    Jun 2008
    152
    Fidia, I have been having the same problems and think I narrowed it down to 1 simple rule. You have to remove or delete the geometry before you reselect. Since I've been doing that I don't seem to crash anymore. Occasionally I forget and guess what, Crash!
    Forrest
    Jun 2007
    394
    Thanks, that seems to have done the trick. Bug I guess
  1. Mach 3 crashes my PC
    By Richster in forum Mach Mill
    Last Post: 03-15-2015, 11:51 AM
  2. A day of software crashes
    By fidia in forum BobCad-Cam
    Last Post: 11-18-2012, 07:46 PM
  3. Bob cad Crashes
    By MLDatus in forum BobCad-Cam
    Last Post: 01-25-2011, 09:44 PM
  4. Does your BobCad crashes or is me?
    By Ed from NY in forum BobCad-Cam
    Last Post: 07-14-2009, 02:38 AM
  5. crashes
    By pyroshizzness in forum Uncategorised MetalWorking Machines
    Last Post: 03-13-2009, 06:27 AM
