603,935 active members*
3,263 visitors online*
Page 1 of 2 12
Results 1 to 20 of 35
    Nov 2004
    12
    Software for Linux
    I jsut built my first 3 axis machine and now I'm looking for software. I need the software to read teh gcode and output step and dir, as well as some cam software for generating teh gcode files. Can anyone recommend any (preferably free) software that will run in linux?
    ringo
    Aug 2004
    3215
    Apr 2004
    678
    And it works fine for me. I recommend the BDI version unless you already know Linux well. Sherline uses it for their CNC mill.
    Aug 2004
    3215
    Quote Originally Posted by ESjaavik
    Since you have used it do you mind posting a review of it here and also some screen shots? that would help people look at it from a glance to see if they would even want to go to the trouble of loading linux and the cnc software..
    thanks, Joe
    Oct 2003
    593
    Great idea. I recently installed Linux (Fedora) on my CNC computer in the garage, just to have a play. Not from a CNC point of view, but out of curiosity. I actually liked it. Seems it has a lot to offer.
    May have to try the BDI and see if I can get EMC running. Would be nice to get more info/screenshots, from people using it here.
    Regards Terry.....
    Nov 2004
    12
    The laptop I want to install this on only has 192mgs of memory so the live version is out. It looks like the other version has the entire version of linux included, so I'm assuming this would overwrite my existing linux, is this correct? I'm using SUSE 9.2 right now and don't want to risk messing it up.
    Ringo
    Apr 2004
    678
    BDI Live will need 256M RAM when run from CD. So one solution is if you can borrow more memory from another machine, install to hard disk, then you can go back to 192M again. When run from CD, it needs RAM to use as a RAMdisk. Then it will not even touch your HD until you choose to install it there.
    I find it hard to do a review of a control program. It's like doing a car review, if you followed my recommendations, you would drive the most twisted roads in your county just for fun, but your groceries would have to be brought home in a wheelbarrow. It all depends upon what you need it for, and what your preferences and background is.
    EMC needs to boot it's own kernel, as it is based on the RTAI real time system that is compiled into the kernel. If you know Linux, it should not be difficult to make it a boot option into it's own partition. EMC cannot be installed just as an application program onto an existing kernel. You can do that if you just want to look at the GUI and run the backplot though. But you can't run your machine then.
    I don't think showing screenshots is very useful for several reasons:
    - There are at least 3 different user interfaces for EMC. You can choose the one you like the best, or even pick the one closest to your liking and customize it. That would be only if you can do a bit of programming though.
    - The user interface is one of the least important points IMO. That's just the "operator panel". It does not help a bit if you like it a lot if the works behind it does not do a good job, and/or it cannot be tied to your hardware.
    EMC is very flexible when it comes to connecting hardware. If you start out with steppers, then find that too limiting and want to change to servos no problem, just fix the .INI file to reflect what you have connected. (Some configurations, like servos without step/dir interface need special hardware. Even though it should be obvious, I mention it). This versatility is the main reason I chose EMC and not Mach2. I don't want to be forced to change control program for running high speed servos which is my next stage.
    If your need for speed is moderate, it can be connected directly from the parallel port to your step/dir drives. There should be a breakout board in between if your drives do not have galvanically separated inputs (optocouplers).
    If you need to go fast, you should consider one of the hardware options that makes this possible. I'm upgrading to pico-systems Universal Stepper Controller. A friend of mine already use it, and his old PC can spit out step pulses faster than any motor can swallow them. Other possibilities are ISAbus or PCIbus analog servo control boards. There are several to choose from at reasonable prices.
    As I mentioned, the user interface can be first chosen, then changed. I have an industrial PC with integral LCD touchscreen that I want to use. As all the source code comes with it, I can adapt whatever needed to exploit that possibility.
    All this adaptablility comes at a price: You should have a bit of stamina to get it running. If not, you should at least choose one of the example setups. The documentation is scattered and not well updated. I found this frustrating at times, but the EMC community is very helpful, and I got a system I feel can do whatever I want to do in future projects. At the moment it is not suited for lathes (no threading), but this is one of the highest on the priority list for EMC2 that is well on it's way. So I stay confident that when I get to retrofitting my largest lathe, EMC2 can do it.
    The closest I found to EMC is Mach2. It's not for me, as it is closed and I would have to live with the existing interface to the drives which to me is not an option, I need more speed and versatility. If you like to just answer "yes" when asked if you want to install, then be up and running the same evening, Mach2 could do that if you just read the nearly excellent manual. BTW, read the Mach2 manual even if you don't intend to use Mach2! My hat off to the guy that wrote it.
    I also lisenced TurboCNC the other day, so I can probably soon see what's in that program. Reason for that is I need a quick and easy replacement for the ancient controller that my Emco Compact5 lathe came with, and as mentioned EMC can't do threading just now. TurboCNC also comes with source code, so even if the 100-hole spindle encoder of the Emco does not fit in with the program, I can choose to alter the lathe or the program. Whichever I feel give the best result.
    Hopefully my ranting have given been of use to you even if it is not a review.
    Aug 2004
    3215
    Thanks for the review. I went ahead and installed the DBI with EMC and right off the bat my CNC Router worked with jogging (did not have to set pins or even flip axis), and the spped control is great, it is a good looking cnc program and i believe i will use it instead of other, the only thing i have to figure out is the TPI i use a 1/2" threaded rod and it has 13 turns per inch and use 1/2 step on the hobby cnc board. I think i need to figure out the number somewhere in the EMC.ini file....
    any help is apriciated.
    How many do we have running Linux EMC????
    Thanks, Joe
    Jan 2005
    56
    I've been playing with this too. INPUT_SCALE = 5200, at least that made it move 1 inch when you told it to move 1 inch. 13tpi , 200 steps per rev, half step mode. I like linux and I haven't tossed this one out yet. You'll need to install to a drive.
    Apr 2004
    733
    The EMC guys just recently released a new BDI version 4.16 based on Debian. You can get it from the Sherline website.
    http://sherline.com/emc/
    I am downloading it now to see what is new since I've been using BDI 2.xx for the past year or so on my converted Harbor Freight Micro Mill. Some minor install issues but it has been running just fine since.
    Jim
    www.embeddedtronics.com
    Apr 2004
    678
    I haven't tried it yet. It is not yet considered a working version as far as I've understood, so you may want to keep your old one. And 4.18 is the most recent.
    Jan 2005
    56
    I used the Live version, then used the install to drive option.
    I just noticed that the axis directions are flipped. How do you fix that? You tell Z to go up, but it goes down. Mach 1 works correctly, so my machine is setup right.
    Apr 2004
    733
    Thanks for letting me know that BDI 4.16 is older. Came home from work and it finished downloading. I now have to find 4.18 and download it instead. Should of checked Linuxcnc.org for latest, I assumed that Sherline would of mirrored the latest version.
    To change the direction of your stepper motor in EMC, you can either
    1) Swap the motor leads on the stepper
    or
    2) Change the emc.ini INPUT SCALE parameter by adding a negative (-) sign.
    For example:
    INPUT_SCALE = -4000 0
    Atleast that is what works for me.
    Jim
    Aug 2004
    3215
    Quote Originally Posted by maxxgraphix
    If you run the live version you can not edit the ini file. you need to do this for the front end you want to run the TKEMC or the MINI, stepper motor increm., and so on.
    Jan 2005
    56
    Quote Originally Posted by joe2000che
    Install to harddrive with the option. Open the .ini file in kedit.
    Open a root console, chmod 777 generic.ini
    Then you can save the ini file with your updates.
    This is assuming that you were logged in as a user, not root. As root you can do anything. There should be a way to point the emc bin to a ini file saved on a floppy.
    Mar 2005
    76
    Install ?
    Can you just install on a PC not hooked up to drives. So you can look things over?
  17. #17
    Jan 2005
    56
    yeah, just use the live version. It will run.
  18. #18
    Mar 2005
    73
    Thanks, Joe
    JOE,
    I have basic unipolar steppers (1.8) I use a simple step/dir controller.
    Find your TPI for the screw.
    For me it is 1.8 stepper at 200 revs per rotation and 16 TPI screw.
    So 200 x 16 = 3200
    Put the 3200 in the input scale/output scale
    input 3200. 0
    output 3200 .0
    Also if you use open loop with no encoders on steppers (bipolar)
    then use stepper.mod in the EMC.INI
    Good luck!
  19. #19
    Apr 2004
    439
    what's the max pulse rate with emc with a printerport?
  20. #20
    Aug 2004
    3215
    Thanks, I got it going, i had to put 5,200 for mine since i use 1/2 step so.
    200x13x2=5,000
    also like to point out to people if your axis are going the wrong way, you need to reverse them by simple putting a - in the number.
    input/output = -5,200.0
    solarchimesam, can you explain what the stepper.mod does? i'm a little confused on that part.
    Thanks, Joe
Page 1 of 2 12
  1. Engraving Software
    By The Wizard in forum Uncategorised CAM Discussion
    Last Post: 03-29-2005, 12:38 PM
  2. Software sales or "license transfers"
    By metlmunchr in forum BobCad-Cam
    Last Post: 07-05-2004, 10:47 PM
  3. ***One stop CNC software guide***
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 05-27-2004, 10:31 PM
