Thanks for the link.
Yes they are great drives, I use them on both my lathe and mill and have a 12.5KW MPL motor and a DSD-HV220 ready to fit on the spindle of the lathe when I get a chance
Hood
Hood
Hood,
I have some AB Ultra 100 drives I am working on and I can communicate to them with DSMpro. The problem is I need to make a custom motor file and DSMpro does not have this feature. I need to download UltraMaster to create the motor files. Do you have a link?
Thanks.
Make a shortcut to DSMPro on your desktop and then right click on it and choose properties. Then in the target box paste the following in place of whats there
C:\DSMPRO\DSMPRO.EXE /A
Then if you use that shortcut to start DSMPro you will have the advanced features available, one of which is the motor config utility
Make sure you paste it or if you do prefer to manually type make sure you have the space between the EXE and the /A that the above address shows.
Hood
Hood,
WOW!!! That was fast. Have you ever thought of going into customer support .
:cheers:
Ha ha nope, would be lost if I didnt have my machines around me all day long
Hood
