587,283 active members*
3,911 visitors online*
Results 1 to 4 of 4
    Dec 2004
    48
    software stops wile running code
    I am having trouble with my foam cutter. While the code is running it just stops at random spots in the code.
    Thanks Bruce
    www.wtxrcdog.com
    http://wtxrcdog.blogspot.com/
    Mar 2017
    1328
    Re: software stops wile running code
    Program execution is stopped? Software still communicates with controller? (buttons on toolbars enabled...)
    Or buttons gray out and you cannot move machine after that?
    Dec 2004
    48
    The software is not communicating with the controllerI
    Have to close and restart the software
    www.wtxrcdog.com
    Mar 2017
    1328
    Which controller do you use?
    Are your motor cables shielded?
    Do you use external power supply for controller?
    Do you use double-shielded USB cable?
  1. Mach3 G-code just stops during run
    By divingdon in forum Mach Software (ArtSoft software)
    Last Post: 06-09-2017, 11:36 AM
  2. Y Axis + Slave not running together when running G-Code
    By Fierra in forum Mach Software (ArtSoft software)
    Last Post: 05-19-2017, 08:56 AM
  3. CNC stops in middle of code.
    By scottgeorgeson in forum Australia, New Zealand Club House
    Last Post: 02-29-2016, 01:32 AM
  4. Gerber 408 motor stops running no error message
    By Comeco in forum WoodWorking Topics
    Last Post: 01-10-2012, 10:39 AM
