This is probably the best stepper selection piece I have seen,in case you havent seen it.
What size stepper motor do I-need.
You need to have data on the rotary inertia of your screws and motor,from there datasheets if possible.Be careful not to mix metric and imperial units and that your using dimensions of the correct magnitude -mm/cm/m eg.
