587,138 active members*
3,827 visitors online*
Results 1 to 11 of 11
    Jan 2020
    9
    Solidcam G code ERROR line 3708
    Hello
    this error occurs when I want to generate the g code
    can you help me ?
    Nov 2017
    44
    Re: Solidcam G code ERROR line 3708
    You need to see line 3708.
    Jan 2020
    9
    you can give me more details ?
    Mar 2016
    325
    In sufficient GPP file is a problem with this line. Maybe just needs to be disabled if the G code looks fine though the error occures.
    Jan 2020
    9
    g code is not generated
    Can I be more specific on how to fix this problem?
    Mar 2016
    325
    Gcode is not generated if u press cancel. If u press ok when the error occures it will be generated anyway. With or without wrong lines.
    Anywhay can U show what line 3708 in MT_Nakamura_NTRX300L_Fanuc31i_XZYCB_BS.gpp looks like?
    Jan 2020
    9
    line 3708 does not exist in the gpp file
    Mar 2016
    325
    Lines are not numbered. U need to look at status bar in notepad.
    Jan 2020
    9
    I found the line
    see the picture below
    Mar 2016
    325
    Try putting ; in front of this line. Looks like problem with procedure get_tool_dir_in_station. Maybe it isn't defined, or missing variables.
    Quite probably it won't harm g-code, or maybe not in every case.
    Jan 2020
    9
    thx
    I managed to put ";"
    now the error below appears see the pictures
  1. Solidcam Error - Can't uncompress CAM-part. Check SolidCAM temporary folder
    By scottbryce in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-28-2018, 03:29 AM
  2. SolidCAM line, arc, rapid G-code in every line
    By iIsTi91 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-13-2018, 06:56 AM
  3. SolidCam Postprocessor with g in every line
    By Gustavo314 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 10-09-2017, 03:20 AM
  4. How to make Mach3 go line by line in the g-code?
    By flyingpickles in forum Mach Mill
    Last Post: 02-07-2015, 09:18 PM
  5. Replies: 3
    Last Post: 04-08-2011, 01:48 AM
