587,129 active members*
2,987 visitors online*
Results 1 to 8 of 8
    Jan 2009
    4
    Solidcam Hurco post
    Anyone know how to get a SolidCam gpp to output absolute rather than
    incremental z values for thread milling? The controller I'm using
    does not have canned thread cycles, but does do helical milling just
    fine. From helical milling jobs, the Z output code from my gpp is
    absolute which works fine, but it always generates incremental Z
    output from thread milling jobs which is a problem. Gota be a simple
    change in the MAC or gpp file somewhere...any quick fix??
    Oct 2007
    499
    Run trace and see what part of the GPP is generating the threadmilling code. The edit that (GPP) code so that instead of incremental (which are calculated in older posts but are output as discrete variables from SC 2010 on) the G code line uses absolute positions.
    One thing to bear in mind is threadmiling usually is declared as a drilling type job in the MAC file so is independent of helical milling in Profile and Pocket jobs. This means that you will have to declare the variables such as diameter, pitch, approach etc. in job parameters when the threadmill drilling job is created.
    Jan 2009
    4
    Solidcam thread milling
    Thanks for the response Bob; I've never used gpp prior to this, and the overall picture is still fuzzy...but here goes...Trace indicates @relative_mode is called, and then @arc is called, generating the thread mill Gcode.
    The thread_proc is set to "N", and nothing is defined in the MAC @thread procedure. The@relative_mode call can be deleted, but the problem remains that the gcode Z position down steps generated are relative, not absolute.
    This controller does not have a "drill" procedure for thread milling so I don't think I want to declare a @drill in the MAC, (Solidcam 2006 version) The @arc gpp which works fine for helical milling is:
    @arc
    ;-- arc plane --
    if arc_direction eq CCW then
    gcode = 3
    else ; CW
    gcode = 2
    endif
    ;if change(gcode) then
    call @gen_nb
    if print_gcode eq true
    {'G'gcode}
    endif
    {[' X'xpos] [' Y'ypos] [' Z'zpos]}
    if arc_plane eq XY then
    {' I'xcenter:xpos_f, ' J'ycenter:ypos_f}
    if change(zpos) then
    zpos=((zstart-zpos)*-1)*(360/arc_size)
    {' K'zpos:zpos_f}
    endif
    endif
    It generates the following gcode format for a helical move with this controller:
    N60 G2 X0. Y-0.65 Z0.0587 I0. J-0.85 K-0.0489
    N65 G3 X0. Y-0.65 Z-0.1 I0. J0. K-0.1587
    N70 G3 X0. Y-0.65 Z-0.2 I0. J0. K-0.1
    N75 G3 X0. Y-0.65 Z-0.3 I0. J0. K-0.1
    etc.
    BUT;
    When a similar helix is generated from a thread job I get:
    N65 G3 X0.2 Y0.2 Z-0.0125 I0. J0.2 K-0.2 F4
    N70 G2 X0. Y0. Z-0.1 I0.6177 J0. K-0.1125
    N75 G2 X0. Y0. Z-0.1 I0.6177 J0. K0.0875
    N80 G2 X0. Y0. Z-0.1 I0.6177 J0. K0.2875
    etc.
    The K value is a term this controller uses in addition to the Z value, for helical interpolation, it describes the signed distance of the slope per 360 degrees, or fraction thereof. Maybe @arc can be modified with some kind of conditional statement to spit out the right format when the job type is threading?
    Oct 2007
    499
    Yes, a simple conditional statement would do the trick. For taht you would need to add a numerical variable to store the old value of zpos and then just add the incremental move. However, might I ask why you don't use your helical milling code that just works fine for thread milling using a step down equal to the thread pitch? Does that give you bad threads?
    Are you using the threadmilling cycle that is resident in SolidCAM? I have never used it - all my posts are configured with threadmilling as a drill job
    Feb 2011
    252
    Programmed postprocessor for Solidcam, contact us at [email protected]
    Nov 2007
    330
    I'm just doing a bunch of parts on my Fadal (Fanuc control) which uses unmodified code from the threadmilling technology. It uses @arc to generate the code. The actual thread I'm cutting is an external 9/16 18TPI and it's doing fine.
    I'm using a heavily modified 9/16 18TPI tap to cut the thread and contrary to what many have told me it's doing a very good job. Just need to carefully tickle the tool offset compensation. Job Done!
    Feb 2011
    252
    hurco postprocesor solidcam
    I may soon be making the postprocessor for Hurco
    [email protected]
    Feb 2011
    252
    [email protected]
  1. Solidcam Post Question
    By oldjag in forum News Announcements
    Last Post: 02-01-2011, 04:17 AM
  2. Solidcam Mazatrol M-Plus post
    By Kaszub in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-19-2010, 10:59 PM
  3. Solidcam post for MX3
    By ind_dsnr in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-24-2010, 01:32 PM
  4. Solidcam Post
    By Pinball in forum Mori Seiki Mills
    Last Post: 11-06-2009, 01:45 PM
  5. Solidcam Post
    By Pinball in forum Haas Mills
    Last Post: 11-04-2008, 10:23 PM
