587,104 active members*
4,272 visitors online*
Results 1 to 12 of 12
    May 2010
    5
    SolidCAM Post: Fanuc Wire EDM
    I need a SolidCAM Post for a Fanuc type Wire EDM. I have a 1991 Hitachi machine that wont read the generated code for Makino or Sodick which is all I have by default with Solidcam 2008.
    When running 4axis programs I need to be able to output X,Y,U,V coordinates.
    Does anyone out there have this post?
    Thanks,
    Wolfe
    Oct 2010
    same problem here...
    Hi, I have the exact same problem, have you figured it out yet? Or does anyone have a post that can manage this?
    thanks
    Oct 2007
    499
    SolidCAm allows users full access to edit and create post processors. Have a look at the GPP help files, download the GPP manual and make a copy of an existing wire post. Then make a CAM program of a test part and (long-hand if necessary) program the code as it ought to be. Then start making changes in your copy of the wire post until you get the CAM / post output matching the sample code.
    Looks easy when you write it like that, doesn't it? It isn't easy but it ain't as hard as some people make out.
    For X, Y U & V co-ordinates, you need to know the rules for when when such co-ordinates come into play then put those rules into logic before putting them down in GPP programming language.
    I don't know of many wire eroders in this area of the forum but there is an active and knowledgable band of post tweakers who are happy to share their experiences. Have a go, there is everything to gain.
    Oct 2010
    I'll give it a try...
    OK thanks, I'm aware of that, I'm used to modify my milling post-processors all the time, but I cant seem to find how to output the U,V coordinates on the Gcode. Guess I'll have to try harder. If I get to some positive results is it OK to post the post-processor here in the forum? So that other people could test it?
    thanks...
    Oct 2010
    I'm back with good news (I think...)
    :banana:
    OK, so here is the my modified post-processor for old wire EDM hitachi machine such as H-cut models with Fanuc controlers, it outputs x,y,u,v in every line block, adds g92 in the x, y insertion point, adds g90 in the beginning, and
    removed all unnecessary code, for me at least...
    Disclaimer:
    I'll not be held responsible for any damage cause by the use of this post-processor, so you need to test it first to ensure there are no problems
    Hope it helps..
    Attached Files Attached Files
    Oct 2010
    ...opps...
    ok, so I just noticed that the toolpath name in solidcam as to start with "X_4***" or else we dont get the U, V output... I'm going try to change that...
    :tired:
    Oct 2010
    ...correction...
    correction, it as to start with an capital "X"... still trying to change that...
    Oct 2010
    ...not easy...
    looks like the solution is to use one capital "X" at the start of every job name for 4 axis toolpath in solidcam tree, and for angle toolpath (x, Y + angle) I've modified it to use G51/G52 and taper (T) only when job name starts with capital "A", as for simple profile (X,Y) it as to start with any other letter/number except "A" or "X".
    I send picture, and new version of post-processor.
    Oct 2010
    WARNING!!!
    this post does not works, after testing the coordinates are wrong... working on it.
    edit: after all it works... sorry my bad
    Oct 2010
    Talking my bad....
    OK, so, the last version I uploaded here is VALID and IT WORKS , I was assuming it was wrong because I forgot to set the "cutting mode" in the machine taper settings to 1, it as to be set to the value "CUTTING MODE: 1", and I was first testing it in cutting mode 10 that didn't work.
    Also you have to set the "program plane" and the "drawing plane" on the taper settings according to the same values you have on your coordsys definition in Solidcam.
    And that´s it
    Feb 2011
    252
    I have to FanucW and a few more for Wire.
    [email protected]
  1. Replies: 1
    Last Post: 04-14-2014, 07:41 PM
  2. solidcam for Fanuc wire cut H
    By stenly in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-21-2013, 11:53 PM
  3. Wire EDM Question-SolidCAM
    By Wolfe88 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-15-2012, 01:07 AM
  4. Anyone have SolidCAM wire EDM experience?
    By Lumenium in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-05-2011, 02:59 AM
  5. FANUC GCode from SolidCAM
    By Jixxer in forum G-Code Programing
    Last Post: 09-04-2009, 07:52 AM
