603,378 active members*
3,049 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Solidworks 3D Help with Loft or Boundary Boss
Results 1 to 5 of 5
    May 2009
    21
    I am trying to create a heart shaped nose on a sign face. The problem is figuring out the best way to go about this. I have been working it for over five hours and I am at my wits end. I know using a lofted boss with points is a bad idea (because it prevents freeform modeling later) and the boundary boss always has errors.
    In the attached pictures I have the outline of the heart on a single sketch and three 2d sketches on separate planes. One side of the heart is flat while the other has an organic and symmetric shape.
    Also a second but similar problem is how to do the bird feet, which is essentially a heart with three crests but not symmetric.
    Any help would be very much appreciated.
    Attached Thumbnails Attached Thumbnails Angle 1.jpg   Angle 2.jpg   Feet Issue.jpg
    May 2009
    21
    Well after fidgeting with it some more I got something close to what i am looking for.
    The tool that i used was the filled surface tool. It wouldnt work previously because I was drawing a line as measurements instead of using the smart dimension tool.
    I believe this is the best solution. Anyone concur?
    Dec 2010
    634
    That looks like it could be accomplished with a boundary surface rather straight forwardly. Give is a shot and if it works, post back. I think with the sketches in your first post, you should be able to do it no prob.
    -Andy B.
    http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
    Oct 2011
    It also might be easier to try modeling half of the heart and then mirroring it.
    The "Z" is silent
    Oct 2011
    Like this, I used boundary surface
    The "Z" is silent
  1. Can anyone help me use the loft boss...
    By cloverfield333 in forum Solidworks
    Last Post: 07-24-2009, 11:14 PM
  2. Zero thickness in cut loft
    By Michael El in forum Solidworks
    Last Post: 06-18-2008, 10:58 PM
  3. my college loft
    By zachjowi in forum WoodWorking Topics
    Last Post: 01-21-2008, 04:38 AM
  4. Boundary box from 9.1 to X?
    By tt_raptor_90 in forum Mastercam
    Last Post: 06-08-2006, 07:24 PM
  5. modifying a loft
    By PTcutter in forum Solidworks
    Last Post: 06-18-2005, 01:22 AM
