603,344 active members*
3,144 visitors online*
Results 1 to 9 of 9
    Apr 2003
    59
    Question Solidworks How?
    Hi All,
    I'm a bit of a 'Newbie' to Solidworks. My boss says that he wants me to learn it so I can use it at work. Anyway after going through the tutorials, I think I am getting to grips with it.
    I would like to get a drawing of a dragonfly and make a dxf/dwg out of it to cut the outline on a waterjet machine, I have tried scanning an image, converting it to a TIFF file and inserting it into a Solidworks drawing, but I keep on getting an 'error reading file' message. Can anyone shed any light on this, and offer some help. I hope to apply the same method to various other pictures, (flowers, birds etc)
    thanks for any help
    Mark...
    P.S. Perhaps there is another program that is better suited to this
    application? Thanks...
    If in doubt ask!
    Apr 2003
    1876
    You need to convert the raster image, (bmp), to vector (dxf, iges etc).
    There's a few programs that do this, wintopo has a freeware one that's barely OK, one of the adobe products which I don't remember the name of off hand works well, and Mastercam has a c-hook to do it. There's others as well.
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Apr 2003
    99
    Adobe Illustrator
    Apr 2003
    1876
    Originally posted by woody5
    Adobe Illustrator
    Yeah, what he said.
    I think it's only in v9 and above, but I might be wrong. (at least the 'stable' one)
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Feb 2004
    28
    Use the graphic as a sketch bitmap and trace it using 3 point arcs and lines. Splines would be faster, but the gcode resulting may be reduced to very small line sements. Arcs and lines produce a predictable path. Arcs also seem to transition into arcs much smoother than line segments due to ramp up/down being executed for each micro movement. Arcs may requires hundreds of line segments to produce an acceptable appearance. This has a huge impact on program length as well. 100 line segments = 100 lines of gcode vs 1 line of gcode to execute an arc.
    Mar 2008
    I'm having the same problem. You should be able to insert a raster image without any problems. There's even an auto trace feature for creating vector geometry by tracing over your picture. It'd sure be nice to be able to use it...
    Jan 2004
    3154
    This is a 4 year old thread that you just resurrected!
    SW 08 definitely has more features than 03 or 04 did.
    www.integratedmechanical.ca
    Mar 2008
    I noticed the oldness afterwords, but it doesn't change my problem with the program. Now that it's resurrected, do you have a solution to the problem?
    Jan 2004
    3154
    You will need to use autotrace or some other raster to vector converter. There are free programs available for this on download.com (raster to vector) or you can use adobe illustrator.
  1. SolidCAM & Solidworks vs. MasterCAM
    By griffithbuilt in forum Uncategorised CAM Discussion
    Last Post: 07-03-2007, 06:46 PM
  2. Is SolidEdge like SolidWorks?
    By fastolds in forum Solidworks
    Last Post: 08-22-2005, 07:27 PM
  3. Replies: 7
    Last Post: 05-20-2004, 08:21 PM
  4. Add on to SolidWorks. New to the USA.
    By SolidCAM in forum News Announcements
    Last Post: 09-03-2003, 03:46 AM
  5. New to Solidworks
    By jimglass in forum Solidworks
    Last Post: 07-04-2003, 03:07 PM
