603,314 active members*
2,009 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Some how broke KMotionCNC X position, how to fix?
    I was working on getting MPG wheel to work and looks in one of my tests I broke the KMotionCNC X number.
    I got my MPG working so I now need to fix the bad position displayed on the screen.
    Is there a clean up program or something that I can run?
    I'm guessing I wrote a bad number in a register that I shouldn't have, and now I can't get it to reset.
    Of course, I tried the turn it off then back on, rebooted everything including my PC, and still can't get the NaN to clear.
    I'm running KMotionCNC 32-Bit 5.3.0
    KFLOP 5.3.0 Build 15:36:19 Sep 18 2023
    KFLOP 5.3.0
    May 2006
    4087
    Re: Some how broke KMotionCNC X position, how to fix?
    You might select to display Machine Coordinates. If that isn’t nan then it must be a GCode offset. In that case, select edit offsets to display offsets and look for a crazy or nan number.
    TK
    http://dynomotion.com
    That was exactly the problem!
    Offset was nan and causing issues like you said.
    Thanks for the quick response Tom.
  1. Before something gets broke
    By J Platt in forum Haas Lathes
    Last Post: 06-18-2013, 07:52 PM
  2. Machine always looses position when I press Escape to stop motion is there a fix?
    By Smertrios in forum Mach Software (ArtSoft software)
    Last Post: 06-05-2013, 10:26 PM
  3. Machine Origin Position Setting (Belt Broke)
    By obieron in forum CNC Swiss Screw Machines
    Last Post: 09-23-2011, 12:14 AM
  4. Something broke in V2.04
    By duenow in forum NCPlot G-Code editor / backplotter
    Last Post: 03-27-2008, 01:16 AM
  5. she,s a broke eh
    By corrie in forum DNC Problems and Solutions
    Last Post: 09-12-2007, 11:08 PM
