603,914 active members*
2,808 visitors online*
Results 1 to 7 of 7
    Jan 2007
    64
    Source for timing belt clamps
    I'm going to be needing some clamps for XL timing belts. I don't mean the kind of clamp that clamps the two ends of the belt together. I mean a clamp that will attach the belt to the moving part of the machine.
    Been looking online, but haven't really found anything. Any ideas where to find such a thing?
    Thanks,
    Neil
    Mar 2004
    761
    Is this what you need? They can be mounted to the axis machine base.
    https://sdp-si.com/eStore/Group.ASP?GroupID=987
    https://sdp-si.com
    Wayne Hill
    Jan 2007
    64
    Thanks, Wayne. I had seen those clamps at SDP/SI, but it looks as though they would require me to make a hole in the belt for the screw to pass through. I'd rather leave the belt intact if possible. Also, my belts are 10mm wide, and I think SDP/SI doesn't have a clamp that wide.
    Mar 2004
    75
    Improvised clamp for toothed belts
    For belt patterns that are the same tooth and cog, you can cut a piece of matching belt several inches long to bridge the connection between the ends of the belt.
    If you are using a continuous belt, place the cut belt on the continuous belt so it cogs.
    Then bolt a flat plate over top of the overlapped pieces to secure it to your machine.
    Bolt the flat plate down tight enough to secure the drive belt.
    Presto!!!
    Jan 2007
    64
    OK, yeah I can do that. I can glue a section of belt to some flat Al, and bolt that to my machine. Cool, thanks.
    Neil
    Apr 2007
    76
    Wink Timing belt connection
    Quote Originally Posted by pixpop View Post
    Neil
    Is it possible to share the photo of belt connection ? I would like to know this concept.
    Cheers,
    Samak
    Jan 2007
    64
    When I get it working, I'll see if I can post a photo. I have to go buy a small length of belt from Mcmaster Carr first.
  1. What is a timing belt and pulley ?
    By ynneb in forum FAQ of DIY CNC Machine Building
    Last Post: 02-18-2011, 01:38 PM
  2. A New Series of 16 Timing Belt Clamps from SDP/SI
    By carolpratt in forum News Announcements
    Last Post: 12-27-2006, 09:41 PM
  3. Seeking Belt Sander Belt Source 6 x 48
    By Dugg in forum Uncategorised MetalWorking Machines
    Last Post: 12-24-2006, 04:48 PM
  4. Timing belt reduction, which to use?
    By phantomcow2 in forum Mechanical Calculations/Engineering Design
    Last Post: 12-30-2005, 06:19 AM
  5. timing belt reduction
    By drwc in forum Benchtop Machines
    Last Post: 05-23-2005, 09:31 PM
