603,936 active members*
3,765 visitors online*
Results 1 to 4 of 4
    Sep 2004
    235
    Spacing for Thomson round rails
    Hi All
    I`m wondering if any one has specs on the spacing of round rails. When I did my diy cnc machine I spaced the blocks 18 inches. I can twist the X axis .008 to .010 by pushing against the Y axis. Even with the looseness in the linear motion system it works OK for wood but I`d like to machine aluminum and steel. I`d like to increase the spacing but will lose travel in the X axis. Somewhere I heard that if your machine was 36 wide that it was necessary to space the blocks 36 inches apart.
    Barry
    Mar 2003
    35494
    Would it be easier to convert to a dual screw drive?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jan 2005
    2010
    I think what you are talking about is "racking" where one end of the bridge advances farther than the other. This usually causes binding or at the very least parts that are out of square.
    If that is the case you might find some assistance here. (I did!)
    http://www.cnczone.com/forums/showth...try+rock+solid
    Mar 2006
    489
    I have the same type of setup as you, hanging the gantry from the rails. I'm in the process now of turning them upside down, so that the gantry rides on top of them. The Thompson rails that I have are not meant to be used in the hanging position.
    Anyways, my machine is smaller, with the gantry width at 30", and my blocks are spaced at 8". I've never had a problem machining aluminum, just some weird oscilations at about 250ipm rapids, which is what I'm trying to fix. Faster is fine, slower is fine.
  1. Thomson 1” x 28” Linear Rails for X axis?
    By eranglr in forum Linear and Rotary Motion
    Last Post: 04-17-2009, 09:06 AM
  2. Thomson Super pillow blocks and thk rails for woodworking
    By endgrainguy in forum DIY CNC Router Table Machines
    Last Post: 10-23-2007, 07:50 PM
  3. 20mm Round cradle for open thomson bearings
    By simso in forum Linear and Rotary Motion
    Last Post: 12-28-2006, 11:52 PM
  4. Which is better, round or square rails?
    By digits in forum Uncategorised MetalWorking Machines
    Last Post: 11-13-2006, 01:09 PM
  5. Linear bearing spacing & Sizing linear rails?
    By fyffe555 in forum DIY CNC Router Table Machines
    Last Post: 12-07-2004, 08:09 PM
