you know how you buy machine parts, rails, motors, and all sorts of suff on ebay, then never actually get around to making them into anything because your intentions change and you then buy more stuf... which you never use... and the viscious cycle continues...
well, i decided i would build a machine from my spare parts and sell it off to recover some money.
parts i had:
- 4 THK precision grade KR46 slides with 22.5" travel and a non standard motor mount.
- 15 parker SM232BE 7500rpm slotless servo motors that dont fit the slides and have no matching drive.
- a fully functioning sieg KX1 which i no longer use because i have a bigger mill.
- a weiss WMD16V manual mini mill which was intended to be converted to cnc.
- a weiss R8 spindle shaft.
- an anorad ironless linear motor with renishaw magnetic encoder.
- an all aluminium linear slide with thk "2 way" RSR15 linear rails this had the linear motor inside it.
- some igus cable chain.
so this is what ive got so far. basically a gantry made from the slides on a granite base.
i now need to determine the spindle. i dont want to buy a new one, and the kx1 has a 500w brushless motor and all the electrical to go with it. then theres the weiss r8 spindle shaft. the r8 spindle will make using tts tools and an auto tool changer possible, so i like this too.
so far the only "hard" part is getting the granite "risers" made. they will be made from a 18x24 surface plate water jet cut in half. ill need to figure out how to lap them flat and parallel or find an alternative. anyone have any ideas?
