603,362 active members*
3,731 visitors online*
    Apr 2006
    11
    spectralight retrofit
    I need some help on the wire color codes of the steppers and limit switches.I seen that other people have redone theres and i would like to see there wiring diagram.Im using the same power supply and motors.any help would be appreciated thanks.
    Apr 2006
    11
    Re: spectralight retrofit fixed
    I figured out the wiring on the 3 axis,it wasnt to bad .I used a tb6600 all in 1 controller and it work awesome ,I also added a forth axis.If anyone need the wiring pm me and i will get it to you.
  1. Looking to retrofit and upgrade Spectralight cnc
    By americanbehn in forum Education - Teachers and Students Hangout
    Last Post: 08-09-2024, 11:27 PM
  2. spectralight 0200 retrofit help
    By recoton in forum Stepper Motors / Drives
    Last Post: 01-03-2016, 07:05 PM
  3. Spectralight retrofit - sorta
    By whateg01 in forum Benchtop Machines
    Last Post: 03-13-2013, 05:02 PM
  4. Need Spectralight help
    By Orangejbird in forum Mini Lathe
    Last Post: 02-07-2012, 06:44 PM
  5. Replies: 31
    Last Post: 11-27-2008, 06:55 AM
