603,895 active members*
4,720 visitors online*
Results 1 to 11 of 11
    Mar 2004
    222
    speed controller?
    pls. take a look at this. Is it any good, if so could someone kindly give
    a specific part value that I could use for other components
    not given.
    thanks.
    mhel
    "This is intentionally left blank."
    Apr 2004
    169
    Looks a bit unrefined. Check out this link: http://www.siliconchip.com.au/cms/A_6105/article.html
    Dec 2003
    24260
    The first link describes the circuit as a AC motor controller which is a bit of a misnomer and might fool someone to think they can run an AC motor other than a Universal type. It is actually a DC motor controller with the bridge present. If you only want to control the Universal hand-tool-router type etc motor, then the bridge can be eliminated and a triac used instead, I can dig up the circuit I have used in the past with components and post it.
    Al
    Albert E.
    Mar 2004
    222
    thanks guys, I'll be controlling a small
    sewing machine motor and/or ryobi ss50 (I got it for $30 CAD, demo).
    My way of ordering online is limited to M.O. and it cost me more to do so.
    Al,
    I'd like to have the circuit if you could find it,
    I'll see if could build it then I would.
    thanks.
    mhel
    Apr 2004
    169
    For such small motors you might be able to use a lamp dimmer with a few additional snubbing componets or just use it as a source for most of the parts.
    Mar 2004
    222
    thanks Tach, I'll try it.
    mhel
    Sep 2003
    1113
    For small loads like that (or a Porter Cable Laminate Trimmer) Harbor Freight sells a router speed controller - you can keep your eyes open on ebay or HF's web site for sales - seems like I got mine for about 15-20 bucks. Cheers - Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Apr 2004
    169
    Have not tried it but apparently the trick to use a light dimmer as a universal motor speed control is to put a 100 ohm 1/2W resistor in series with a 0.22uF capacitor, across the triac power leads.
    Dec 2003
    24260
    This is the zipped circuit in dxf .
    Al
    Attached Files Attached Files
    Albert E.
    Dec 2003
    24260
    ....And if you want a more sophisticated controller here is a link ttp://www.onsemi.com/pub/Collateral/TDA1085C-D.PDF
    This is also used for treadmills etc.
    Al
    Albert E.
    Mar 2004
    222
    thanks,
    I'm finding lots of circuits now, just
    trying to figure which one would be
    good enough for my use.
    --If any1 looking for (less expensive, that's what they say)solid state relay this
    looks interesting.
    mhel
  1. Taig Mill, US Digital MS23, Controller???
    By marjamar in forum Taig Mills / Lathes
    Last Post: 02-07-2007, 04:16 PM
  2. Open Source CNC Controller Specification
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 12-05-2005, 04:58 AM
  3. I'm looking for a simple speed controller for a brushless AC motor.
    By trilect in forum CNC Machine Related Electronics
    Last Post: 05-12-2005, 02:45 AM
  4. Does controller change axis motor speed?
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 10-10-2003, 10:05 PM
  5. Speed Controller recommendations?
    By paulried in forum DIY CNC Router Table Machines
    Last Post: 05-13-2003, 11:39 AM
