603,897 active members*
5,777 visitors online*
Results 1 to 5 of 5
    Spindle Bracket Removal
    Working to downsize from a Porter-Cable bracket to an 80 mm Spindle.
    I finally got all the parts and prewired the VFD - so I started the teardown,
    I used locktite during build and now I cannot loosen the (10-32 I think) screws more than about one turn.
    Can't tighten back either - guess I shouldn't have used the red stuff.
    So, I can't use the router and I can't remove the bracket.
    I need my machine up and running ASAP and was looking for advice or the P/N to buy a replacement Z-Axis plate.
    Comments welcome
    I use the Saturn almost daily and it is a great tool for everything I do.
    Decided to go away from the air cooled router primarily to help manage dust.
    Mar 2003
    35494
    Re: Spindle Bracket Removal
    Put a torch on the screw heads for 30 seconds.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Thanks for the suggestion - I tried propane and held it on the bolt threads from the back side (removed the Z-axis plate from the machine) for a couple minutes. Still not getting it. I read where the Red needs to be heated to 500 degrees before letting go. Easier said than done using a propane torch on a block of steel the size of the Z-Axis plate. So I'll keep trying but it's kinda tough getting a 1/8 Allen wrench in the pocket with the metal at that temperature.
    UPDATE!: With the help of my lovely wife, we were able to heat the entire Z-Axis plate to reach the 500 degrees needed to break the Loctite free. This took about 30 min for the first bolt and another 5 minutes for the following three. Needless to say, both pieces (plate and spindle mount) were pretty hot when we finished.
    May 2012
    114
    Hopefully the linear bearings (that have a lot of plastic internally) that are attached right behind the plate took no damage from the heat...
    Quote Originally Posted by MonsterRobotics View Post
    Nov 2014
    714
    It's a little late but it is much easier to use a ratchet with extension through the holes in the front. Mine went on in minutes using the tools shown here (and blue is sufficient for these bolts) - glad you got it off, though.
    David
    Attachment 367358
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
  1. Warning for cracked spindle bracket
    By A_Camera in forum DIY CNC Router Table Machines
    Last Post: 11-10-2016, 12:01 PM
  2. Manual 5 Axis CNC Router? 9 Position Spindle Bracket Head
    By Doctor Bombeii in forum DIY CNC Router Table Machines
    Last Post: 04-15-2016, 02:06 AM
  3. wiring to 400W CNC Spindle With Mount Bracket with C10
    By alhaddar in forum Spindles / VFD
    Last Post: 02-03-2015, 08:48 PM
  4. Replies: 5
    Last Post: 07-19-2013, 05:16 AM
  5. NM-135 spindle removal (help)
    By keithmcelhinney in forum Novakon
    Last Post: 01-08-2013, 05:18 PM
