587,466 active members*
3,075 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Spindle brake fuse blows intermittently
    Apr 2006
    43
    6 months ago the spindle would not stop. I found the regen resitor 10 amp brake fuse inside the inverter was blown. I replaced the fuse. I also found one of the inverter cooling fans was dead. I replaced both fans.
    Then last month the fuse blew again. I replaced the fuse and both regen resistors and added an extra cooling fan beside the regen resistors.
    Today the fuse blew again. I think there must be a problem with the inverter but I need someone to confirm this before spending $4000.00 , Thanks.
    Mar 2003
    900
    Before you spend the money for a new drive unit I would have the spindle motor meg'ed out. A failing motor can cause an overdraw. That could in turn cause premature drive failure.
    Neal
  1. Spindle Fuse?
    By dafowfidy in forum Syil Products
    Last Post: 05-04-2007, 09:46 PM
  2. How does your spindle brake work?
    By jnutter in forum Centroid CNC Control Products
    Last Post: 03-28-2007, 10:23 AM
  3. Cemtroid1 controller board blows its fuse :(
    By dm.mcgahee in forum CNC Machine Related Electronics
    Last Post: 12-27-2005, 03:55 AM
  4. EZ Trak Spindle Brake Adjustment?
    By melamark in forum Bridgeport / Hardinge Mills
    Last Post: 12-06-2005, 12:59 AM
  5. 3 axis lathe spindle brake
    By atmosports in forum Uncategorised MetalWorking Machines
    Last Post: 07-28-2004, 08:30 PM
