603,982 active members*
2,105 visitors online*
    Jul 2006
    Spindle configuration
    Dear friends. Sorry, but my English is not good. I have a problem with Mach PWM spindle control. I use ncPod board and it work perfect. I connect PWM to Digital converter and config Mach. After them I connect voltmeter to PWM converter output (0-10V) and I have controling voltage. If I input in Mach 18000 rpm I view 9.97V on voltmeter. But my spindle max 24000 rpm! Also I input less 8000 rpm then view on voltmeter 0V. I dont find spindle preferences in Mach. Where is I input min and max spindle rpm?
    May 2006
    179
    Smile
    config, spindle pulleys will get you there. Other settings you will need are in config, ports and pins, motor outputs (to enable spindle), config, ports and pins, spindle (will needs to be set up), config, motor tuning
    Hope this helps !!
    Good Luck
    Kirk
  1. Configuration???
    By derekreuvekamp in forum LinuxCNC (formerly EMC2)
    Last Post: 03-31-2008, 03:25 PM
  2. Axis configuration, please help.
    By alexccmeister in forum MetalWork Discussion
    Last Post: 06-25-2007, 11:38 AM
  3. ANSI A2-5 Spindle Configuration
    By Crashmaster in forum MetalWork Discussion
    Last Post: 06-20-2007, 07:25 PM
  4. Pin Configuration for minitech2
    By gone4pepsi in forum Mach Mill
    Last Post: 02-07-2007, 04:37 PM
