603,417 active members*
3,032 visitors online*
    Feb 2007
    33
    "SPINDLE DRIVE FAULT"
    I HAVE A 412 INTERACT WITH A TNC 2500 AND I HAVE MOVED THE MACHINE TO A DIFFERENT LOCATION AND WHEN I BOOT IT UP I AM GETTING A "SPINDLE DRIVE FAULT". I HAVE SWITCHED WIRES THINKING IT WAS A POLARITY ISSUE BUT NOTHING GOOD. THE MACHINE RAN FLAWLESS BEFORE I MOVED IT TO ANOTHER LOCATION. HELP NEEDED, PLEASE. THANK YOU
    Mar 2003
    4826
    Check all connections by turning the power off and test tightening all screws, that's where I would start. Not only the main power conductors, there might also be some skinny wires going to a terminal strip on the drive, and some of those can be on a 'fault reset' type circuit. Gently pull on the wire at every crimped connection to make sure the crimp is holding good.
    First you get good, then you get fast. Then grouchiness sets in.
  1. "low end" HF Spindle or "high end" router for about $1000?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 01-06-2012, 07:15 AM
  2. "amplifier fault on axis" on fadal VMC 15
    By siquedude in forum DNC Problems and Solutions
    Last Post: 11-21-2007, 12:11 AM
  3. "Astrosyn Miniangle Stepper" Power Drive
    By hferraz in forum Stepper Motors / Drives
    Last Post: 10-31-2007, 09:27 PM
  4. V2XT error message "DRIVE FAULT detected (0,z,y,x) check log"
    By rfdoyle in forum Bridgeport / Hardinge Mills
    Last Post: 10-08-2007, 09:35 PM
  5. Replies: 4
    Last Post: 05-17-2006, 11:19 AM
