587,167 active members*
3,560 visitors online*
Results 1 to 7 of 7
    Apr 2008
    27
    Spindle Drive Problem
    Hi every one I have the drive and motor are of kollmorgen / inland motors
    Machine : Harding Lathe
    Model: CHNC4
    Spindle Drive: HPA03-158100-611-5306B35
    Serial : 4M-405
    Spindle Motor: TTBH5306-425-B
    Serial No.: 84K72-275
    The Problem is that motor is giving a humming noise and at high speed there is vibration. We have checked the motor by giving external power Motor is fine no sound. Then we checked the current input of spindle drive. the Voltage are same but the current varies alot on one wire it reads 25 amps, second it is 12 amp and third is 2 amp. can you suggest please where the problem lies and its solution. thanks its is urgent
    Feb 2009
    6028
    Did you check the Tach on the motor? Sounds like a tach feedback problem to me.
    Apr 2008
    27
    thanks for quick reply. what is needed to be checked in tacho (I have seen it, physically it is in good condition). do you think tacho can cause the huge difference in current input.
    Sep 2008
    19
    I'd check line to line resistance of the motor. Disconnect all three motor wires and measure resistance from 1 to 2, 2 to 3, and 1 to 3. Should all be around a few ohms. If one is much different than the other then there could be a problem with the motor coils.
    Also check each line to GND. If one leg is shorted or has a low resistance to GND it will pull more current than the other legs.
    Feb 2009
    6028
    Yes I do. if it's not getting a stable feedback, the drive will try to adjust the current to maintain constant speed. This usually ends up in blows transistors, as the drive will work too hard. A old analog meter is about the best to use to check it. Just watch for voltage fluctuations at a constant speed.
    Apr 2008
    27
    Quote Originally Posted by cnc_guru_guy View Post
    Hi, I think you misunderstood me. I am attaching the drawing of the machine. if you see spindle drive and connection strip P01. we connected a variable DC power supply to 4 and 5 and increased the voltage and motor worked fine without a sound or vibration. then we checked the current on 8,9 and 10. there it shows the variation in current
    Attached Files Attached Files
    Apr 2008
    27
    Hi, I have checked the techo and it is working fine. I removed the wire of reverse SCR. The problem of sound was solved but there was still difference in phase current from transformer. Now if I remove the wire from reverse direction motor wont stop instantly. any suggestions
  1. FR-SE spindle drive problem
    By kudos in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-05-2010, 02:25 AM
  2. AC Spindle Drive Problem
    By leeng in forum Colchester Tornado lathes
    Last Post: 06-08-2010, 11:42 AM
  3. Problem with 6M spindle drive
    By BigDamo in forum Fanuc
    Last Post: 04-17-2009, 02:51 PM
  4. A different (?) spindle drive problem
    By zephyr9900 in forum Tormach Personal CNC Mill
    Last Post: 03-01-2009, 09:10 PM
  5. Spindle Drive problem - need help ;)
    By Dancy in forum Fanuc
    Last Post: 02-02-2008, 12:26 AM
