588,445 active members*
5,188 visitors online*
    Dec 2005
    55
    Spindle Overload Monitoing....
    We have 2 Nakamura Tome TW-10's, one a Fanuc 18T and the other with a Fanuc 16TT comtroler. I'm trying to set up a macro that will shut down the machine at a certian spindle load. The problem being is that if a tool breaks on the left side and say the bore is missing, when the right chuck comes in for the transfer, it will crash. I have found a macro program on the net for this but I cant make sense of the parameters involved to do this. Here is the info I have found.
    Installation and operating Instructions for load monitoring
    Introduction
    The following deals with the operation and installation of the load monitoring function. This function allows you to monitor the load on a tool each time its used. Two values are set, A and B. The controller will monitor the load on the tool and if it reaches the percentage value of A it will warn the operator that it has reached this value and the feed rate will automatically decrease. If it reaches the B value then the controller will stop what ever operation the machine is carrying out and it will display an alarm message to tell the operator to check if the tool is broken or worn.
    The following instructions will deal with the following ROM version number,
    MA0LSP-1 And, MA0LSP1G
    This function uses a macro program and it is located at the following address,
    Macro ~ PMC
    #1132 ~ F162
    #1133 ~ F196.0
    Parameter Changes
    In order to activate the function in the controller the following parameters have to be changed,
    Parameter
    Setting Value
    Comment
    913.6
    Activate Macro
    913.7
    Activate Macro
    230
    92
    This is the number of the macro program O9020
    10.4
    Protects the macro program so it cant be overwritten
    Note: When the macro program is written into the controller, make sure the parameter 10.4 is set at 0. Upon completion of inputting the program set the parameter to 1, so it can not be accidentally deleted.
    Diagnostics Changes
    Diagnostic
    Setting Value
    Comment
    D447.0
    Spindle Overload Monitor Function
    D447.1
    Machine still runs when it reaches the A value
    D310
    1000
    Delay time for the message to stay on the screen
    The A and B Value
    The A and B value are dependent on the material and the cutting conditions. They are percentage values equal to the spindle load percentage. The maximum setting load for the B value is 150%. The two values can be set into the range of 1~150%.
    The M-codes associated with this Function
    M90 Opens the spindle load monitoring screen.
    M91 Displays the value.
    M92 Sets the A and B value.
    M93 Reset.
    Alarms
    Alarm 600 - B VALUE SETTING ERROR
    This means that B is less than or equal to 0.
    Alarm 601 - A VALUE SET TOO LARGE
    The A value exceeds 150.
    Alarm 602 - B VALUE SET TOO LARGE
    The B value exceeds 150.
    Alarm 603 - A VALUE SETTING ERROR
    This means that A is less than or equal to 0.
    Alarm 604 - A OR B VALUE NOT SET
    A or B equal 0.
    1022 TOOL OVERLOAD
    If this is displayed the machine is stopped and the tool must be checked. Once the controller is reset the alarm will disappear. It is advised to change the tool.
    Sample Program
    Example 1: Dry Run Program
    O****
    M90;
    M91;
    T0101;
    M3 S1000;
    G04 X2.0;
    G01 Z-100. X-20. F1.;
    G28 X0. Z0.;
    M01;
    T0303;
    M3 S1500;
    G04 X2.0;
    G01 Z-100. X-20. F2.;
    G28 X0. Z0.;
    M01;
    M93;
    M30;
    Example 2: The Production Program
    O****;
    M90;
    M91;
    T0101;
    M3 S1000;
    M08;
    G04 X2.0;
    M92 A5.0 B35.0;
    G28 X0. Z0.;
    M09;
    M05;
    M93;
    M30;
    The Macro Program
    O9020(Load Monitoring Program);
    IF[#1 LE 0.] GOTO5;
    IF[#2 LE 0.] GOTO2;
    IF[#1 GE 151.] GOTO3;
    IF[#2 GE 151.] GOTO4;
    IF[#1 EQ #0] GOTO6;
    IF[#2 EQ #0] GOTO6;
    IF[#1 GE #2] GOTO2;
    #10=0;
    #1133=1;
    #1132=#2;
    WHILE[#10 LT 50]DO1;
    #10=#10+1;
    END1;
    #10=0;
    #1133=0;
    #1132=#1;
    #10=#10+1;
    END2;
    M92;
    #10=0;
    IF[#1 LT 151.]GOTO100;
    N2 #3000=100 (B VALUE SETTING ERROR);
    N3 #3000=101 (A VALUE SET TOO LARGE);
    N4 #3000=102 (B VALUE SET TOO LARGE);
    N5 #3000=103 (A OR B VALUE NOT SET);
    N100;
    M99;
    Can anyone help me make sense of this?
    Thanks,
    JK
    Jan 2007
    91
    I think the problem with this load monitoring program is that it will only read the load meter parameters one time at the time the O9020 is called. You need a program that will run in the background all the time to monitor loads. I think that would have to be done on the ladder logic side. I might be wrong and their are some guys on this forum way more advanced than me that will let me know my error Maybe something like this would work if you could read two macros at once??? I would like to monitor my spindle loads during milling with a macro also.
    May 2006
    265
    If the problem is to determind if any critical tool breaks, you could always use automatictoolcompensation and have a macro to decide if the tool are worn out/broke. (the presetter option is needed)...
  1. Y-axis overload
    By cdlenterprises in forum MetalWork Discussion
    Last Post: 04-21-2007, 11:03 PM
  2. spindle motor overload
    By RdHawg in forum Uncategorised MetalWorking Machines
    Last Post: 12-06-2006, 08:02 PM
  3. Help!!! Y axis overload won't go away
    By soweebee in forum Bridgeport / Hardinge Mills
    Last Post: 06-15-2006, 03:15 PM
  4. Spindle overload switch
    By Anchor in forum DNC Problems and Solutions
    Last Post: 05-26-2006, 07:18 PM
  5. Spindle motor overload, DX 32 control
    By Gncc50 in forum Bridgeport / Hardinge Mills
    Last Post: 11-15-2005, 07:49 AM
