603,894 active members*
3,056 visitors online*
    Apr 2006
    1016
    spindle / router on function
    can someone explain how to control my router on off via mach or emc
    Is there a step by step some where?.. What actual triggers the event
    the gcode or something in mach?
    Or do i just need a header within the g code to trigger the even on off?
    Jun 2004
    6618
    It can be a bit involved depending on what you actually have as hardware.
    The Gcode will turn on a router or spindle as well as turn it off or change directions and tell it what speed to run.
    That is generally coded in your Cam program, but I think for some things, you can do that in Mach with wizards.
    I have a relay that actually does the turning on of my router. I have a speed control board that does it on the mill.
    There are also several settings on different pages that need to be setup in Mach depending on just what you are turning on.
    I don't know of any real step by step lesson plans, but the instructions in my speed card for the mill from Homann Designs was quite useful.
    http://www.homanndesigns.com/DigiSpeed_SD_User010.pdf
    Lee
    Mar 2003
    35494
    A simple M3 in the g-code will turn it on, and M5 will turn it off. In Mach3, you set up an output pin to activate a relay to turn on the router. You assign the output to the M3 command in the Ports and Pins screen, spindle tab.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Router Spindle
    By Brian2007 in forum Want To Buy...Need help!
    Last Post: 08-06-2008, 09:33 PM
  2. router vs a spindle
    By woodman08 in forum WoodWorking Topics
    Last Post: 01-15-2008, 10:55 PM
  3. spindle vs router plz help
    By mjs79 in forum DIY CNC Router Table Machines
    Last Post: 09-20-2007, 10:38 PM
  4. cnc router spindle
    By .xXACEXx. in forum DIY CNC Router Table Machines
    Last Post: 06-30-2007, 03:14 AM
  5. UK router spindle?
    By kong in forum DIY CNC Router Table Machines
    Last Post: 08-25-2003, 03:27 PM
