586,033 active members*
3,532 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > spindle serial link error 750 Fanuc 21i
Results 1 to 7 of 7
    May 2008
    4
    on our milling machine, when we start this message is diplayed.
    on the spindle servo Amplifier module,
    1) only green LED is on
    2) _ _ is flashing
    the diagnostic parameter 409 bit#1, S1E=1
    the parameter 3701 all bits are = zero.
    we have checked the cables also
    kindly help in this connection.
    Nov 2007
    68
    Re: spindle serial link error 750 Fanuc 21i
    Quote Originally Posted by Abdul Haq View Post
    2) _ _ is flashing
    I have exactly the same problem with same statues .... are you fix it ? how ?
    Oct 2015
    11
    did you check the output dc of you power supply amp spindle?
    check that one....
    Nov 2007
    68
    we checked the power supply output and it's ok
    Oct 2015
    11
    can you send some photo?...
    Nov 2007
    68
    photo for what?
    Sep 2013
    13
    2) _ _ is flashing
    On the off chance you remember or are even still around.... did you figure out the issue. I have the same thing at the moment.
  1. Replies: 0
    Last Post: 05-01-2010, 08:46 AM
  2. spindle serial link error 750 Fanuc 21i-MB
    By Abdul Haq in forum Fanuc
    Last Post: 05-13-2008, 11:59 AM
  3. help!: spindle serial link error
    By emonje in forum Fanuc
    Last Post: 05-09-2008, 04:07 AM
  4. Alarm 408 Spindle Serial Link Start Fault
    By boricuajdm in forum Fanuc
    Last Post: 04-23-2007, 06:26 PM
  5. Alarm 408 Spindle Serial Link Start Fault
    Last Post: 04-21-2007, 05:19 PM
