603,800 active members*
3,296 visitors online*
Page 2 of 2 12
Results 21 to 28 of 28
  1. #21
    May 2006
    4090
    Re: Spindle set up and tapping
    Hi Ben,
    Thanks for posting. But I don't see a problem in the lastest Version:
    <>\C Programs\ToolChanger\Linear4ToolHolders\Linear4Too lHolders Rev2.c
    I see this which looks correct.
    Code:
    // - Load new Tool (Spindle must be empty)
    int LoadNewTool(int Tool)
    	// - Move to position of requested tool
    	// - Rapid move to absolute position of new tool only in X and Y
    	if (MoveXY(ToolPositionX(Tool),HOLDER_Y,SlowSpeed)) return 1;
    	// - Move to tool Z position at TOOL_RETRACT_SPEED_Z
    	if (MoveZ(HOLDER_Z,SlowSpeed)) return 1;
    TK
    http://dynomotion.com
  2. #22
    Jun 2013
    1041
    Tom
    I used the program in 435.d. The line I am referring to is not shown in what you posted. I will try to get a screenshot of where I found the issue and post it this evening.
    Ben
    Sent from my E6910 using Tapatalk
  3. #23
    Jun 2013
    1041
    I copied this from the wiki and it shows the error I was referring to.
    // Move Axis XY at specified Speed and wait until complete
    // return 0 = success, 1 if axis disabled
    int MoveXY(float x, float y, float Speed)
    MoveAtVel(AXISX, x * CNT_PER_MM_X, Speed * CNT_PER_MM_X);
    MoveAtVel(AXISZ, y * CNT_PER_MM_Y, Speed * CNT_PER_MM_Y);
    You will see the y move calls axisz but determines the move based on y.
    Ben
  4. #24
    Jun 2013
    1041
    Tom
    I am having a few issues I need to address concerning my linear atc program and other safety features with a tool changer. I was running a program and it went to make a tool change and it errored out because it didn't release the claw because I had not turned on the air. That is great because it prevents things from being destroyed. Unfortunately I ran the program a bit later and didn't require a tool change. Once things started running I realized the air still wasn't on so no air seal. I hit the air valve and realized a moment later the tool ejected from the spindle while running. The vfd shut down and was protected but the spindle was locked up hard and I believed probably destroyed. Luckily when I got up the nerve to start taking the spindle apart I found the problem and the spindle is fine. All my fault but I need to make sure it can't happen again.
    First when the tool changer program errors out because the claw doesn't eject it leaves the tool release bit on. I looked at the program but am not sure how to tell it to turn that bit back off when it sends the error message.
    I would also like to have kmotion cnc check that the tool release bit is off before it will run a program.
    Last I would like to tell the bit to turn off any time m3 is executed. I think that should just be a matter of putting a clear bit command in the spindle on program but I'm not sure if that is appropriate or the best way to do it.
    Any help would be appreciated and i am open to any better suggestions to accomplish the same outcome.
    Thank you
    Ben
  5. #25
    May 2006
    4090
    Hi Ben,
    Please post your Tool Change Program and your M3 Program.
    What do you mean by: "I hit the air valve"?
    Which bit is the "tool Release Bit"?
    TK
  6. #26
    Jun 2013
    1041
    Thanks for getting back with me. The files you requested should be attached.
    The air to the machine is turned off with a manual ball valve. I had it turned off when I ran the program. When I noticed it was off I turned the valve on because of the bearings air seal. The worst part is I new that this whole senerio could happen and did it anyway.
    The tool release bit is 12. Spindle on is 10.
    My goal is to somehow make sure both bits are never on at the same time. If 10 is on it would be good to not allow 12 for at least 5 seconds. I even thought maybe they could be watched from a forever loop in the initiation file and stop all motion and send a error message while also keeping them from both being on. Maybe force them both off. I don't know really what would be the best way or how to accomplish it.
    Thank you
    BenAttachment 461164Attachment 461166Attachment 461168
  7. #27
    May 2006
    4090
    From what I understand this code detected the Claw was not "loose"
    Code:
    	// - Read CLAW_LOOSE bit to see whether the tool is loose, to make a safe Z move without
        //      destroying tool holder
    	// - If CLAW_LOOSE bit is high, something has gone wrong;
    	//		halt everything and display message indicating failure
    	if (!ReadBit(CLAW_LOOSE))
    		printf("Claw Loose Error\n");
    		MsgBox("Claw Loose Error\n", MB_ICONHAND | MB_OK);
    		return 1;
    So if you want the claw re-engaged I think you would add:
    ClearBit(CLAW_EJECT);
    Before printing the error message.
    To watch for both on in a forever loop I think the test would be:
    Code:
    if (ReadBit(SPINDLECW_BIT) && ReadBit(CLAW_EJECT))
        ClearBit(SPINDLECW_BIT);
        DoPC(PC_COMM_ESTOP);
        printf("EStop - Spindle active with Claw Released\n");
    TK
  8. #28
    Jun 2013
    1041
    Thank you Tom. I think that will do exactly what I want. I will test it out and let you know how it goes.
    Ben
Page 2 of 2 12
  1. Help with Rigid Tapping on Sub-Spindle
    By cjhayes in forum Fanuc
    Last Post: 03-12-2020, 07:33 PM
  2. Spindle for Tapping
    By florianb in forum Uncategorised MetalWorking Machines
    Last Post: 11-07-2015, 06:25 PM
  3. tapping with spindle
    By eloid in forum CNC Wood Router Project Log
    Last Post: 08-30-2014, 09:10 PM
  4. Spindle for Drilling/Rigid Tapping
    By dbc1218 in forum DIY CNC Router Table Machines
    Last Post: 02-23-2013, 03:27 AM
  5. spindle orient when tapping
    By kendo in forum Okuma
    Last Post: 11-26-2009, 06:38 AM
