586,058 active members*
3,366 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Spindle Speed Fluctuate
Results 1 to 4 of 4
    Dec 2021
    54
    Hi.
    I am having problem of spindle speed fluctuation. My rpm goes +-500 to +-800 up and down always amd doesn't remain constant
    My machine have 1.5kw 400hz water cool spindle with ae-200 vfd.
    Need help as this problem effect my aluminum milling jobs.
    One thing more. It doesn't fluctuates when rpm set to 24000
    Also i check. My spindle is ground correctly my machine is ground correctly and my vfd main 220v is ground correctly
    Dec 2021
    54
    Re: Spindle Speed Fluctuate
    https://youtu.be/6-l8fr6J8lo
    Here is the link of my problem. I set it 10000rpm but rpm doesn't remain constant it increase and decrease by itself
    Dec 2021
    54
    Jan 2005
    15362
    Quote Originally Posted by Chmfhm View Post
    At 10,000 RPM you don't have much torque
    How many amps is your mains power supply to the machine??
    The VFD Drive you have is not very good as well so you can't expect very much from it, try lighter cuts and see it it does the same thing.
    Mactec54
  1. Replies: 7
    Last Post: 07-15-2021, 05:24 AM
  2. high speed and low speed dual spindle CNC mill
    By GusBiz in forum Mechanical Calculations/Engineering Design
    Last Post: 02-13-2021, 08:54 AM
  3. Replies: 3
    Last Post: 04-20-2019, 11:24 PM
  4. Replies: 1
    Last Post: 08-02-2013, 10:07 PM
  5. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
