587,999 active members*
3,658 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Spindle Speed Monitoring
    Apr 2012
    Hi guys !
    I need help on my Okuma machine. I'm developing a supervisory system and I want to get a signal with the speed of the machine spindle.
    The inverter unit for the spindle is a MIV22-3.
    It have a DB-15 femmale connector that is used for "SWM Monitor Unit" and, with this monitor, I can measure Motor Speed and Torque in a -3V +3V range.
    But I don't have this "SWM Monitor Unit". Somebody knows the pin configuration for this DB-15, so I can try to get this data directly from the connector ?
    Thank you !
    Jan 2009
    74
    This connector is outputting data to a special SWM unit that communicates via RS232. This connector isn't just supplying the speed singles. You can purchase the SWM unit from the Okuma Latina America office.
    Feb 2009
    11
    Did you ever purchase this unit? Is it a simple RS232 converter with A/D conversion on the input side? Looks like the two velocity signals (AA and AB) are in quad on the original drive. Interested in a picture and pinout if you have the SWM Monitor.
  1. Macro for spindle Load monitoring
    By stoddgopats in forum Fanuc
    Last Post: 05-05-2012, 11:09 PM
  2. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
  3. Spindle speed not 100%
    By AndyB in forum Fadal
    Last Post: 07-14-2007, 02:52 AM
  4. Spindle Speed
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 01-28-2007, 05:40 AM
  5. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
