587,998 active members*
1,506 visitors online*
    Question spindle speed sensor
    Hello all
    I have a BP running 4 axis with Mach 3.
    I need to be able to have some kind of spindle sensor so that if the spindle shuts down....the Mach 3 prog will quit or error out.
    My machines are over 30 years old and stuff happens. It has happened 4 times so far and I spoil a cam when I does.
    If I had a sensor that said or detected that the spindle has or is slowing down,,, the program would stop or error out.
    Can anyone help?
    Thank you in advance
    Never Give Up
    Dec 2003
    24220
    What shuts the spindle down? How is it controlled?
    If it is a contactor overload trip, there is often a spare contact on the O/L.
    If it is VFD, then there should be an alarm output.
    Al.
    Albert E.
  1. Axis movement speed adjusted by pressure sensor
    By Viesturs in forum Controller & Computer Solutions
    Last Post: 05-20-2009, 12:44 PM
  2. Taig / Digispeed XL spindle index sensor
    By Dfennell in forum Taig Mills / Lathes
    Last Post: 01-02-2007, 06:23 AM
  3. Mounting a Speed Sensor on a BP step pulley mill
    By titchener in forum Bridgeport / Hardinge Mills
    Last Post: 03-22-2006, 12:02 AM
  4. Installation of spindle speed sensor
    By Bloy2004 in forum CNC Machine Related Electronics
    Last Post: 01-28-2004, 04:50 AM
