603,940 active members*
2,177 visitors online*
Results 1 to 9 of 9
    Sep 2011
    474
    Spindle spinning in reverse
    Does anyone know how to fix this? Im afraid to monkey with the wiring on the new sensorless vector drive but the wiring is solid according to the directions. Unfortunately the spindle spins in the wrong direction. Could it be a setting in Mach 3? I can switch the manual toggle on the front enclosure to to "reverse" to get it to spin correctly, but when I run any code it goes back to reverse rotation.
    THoughts?
    Apr 2013
    1780
    Re: Spindle spinning in reverse
    Generally swapping any pair of the three leads between a VFD and a 3-phase motor will reverse the direction of rotation while keeping everything else unchanged.
    Sep 2011
    474
    Quote Originally Posted by kstrauss View Post
    So it doesnt matter which pair? Is there anything that would cause this since nobody else seems to have this issue?
    If it just started this it's probably Mach3. Since it works correctly from the main control panel if I understand correctly. Reload Mach3 see what happens. Yes swapping any two wires reverses direction.
    RAD. Yes those are my initials. Idea, design, build, use. It never ends.
    PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, 4th
    Sep 2011
    474
    Ok, Ive read that swapping the A and C lines is the most common practice. My wires are labeled U W V so thats no help.
    And this all started when the new VFD was installed so far as I can tell. I havent run the thing in so long due to driver issues I cant remember when it ran correctly last. I do remember making cuts "manually" but had to reverse the rotation on the panel control board to make it work.
    And its a new install of mach 3.
    Oct 2012
    87
    Hi Swampdonkey,
    A,B,C 1,2,3 U,V,W. All the same just swap ANY two output wires on your VFD to the motor. This will reverse the rotation.
    It's better to ask than let the magic white smoke out.
    Alan
    Sep 2011
    474
    So apparently I cant edit posts on here for some reason.
    But which wires should I swap? On the motor inside the little box on the side?
    Sep 2011
    474
    Ah! It seems to have worked. I swapped out wires 400 and 402 from the VFD to the motor. Seems to work OK.
    Thanks a ton. As usual, you guys are invaluable!
    :cheers:
    Nov 2010
    291
    Did you get your new drivers figured out yet?
  1. Ways to attach collet to a spinning spindle
    By mvoltin in forum CNC Tooling
    Last Post: 06-15-2014, 09:56 PM
  2. Spindle ON = Servo motors spinning in all axis (interference)
    By MecAut in forum Servo Motors / Drives
    Last Post: 07-11-2013, 01:35 PM
  3. Sieg KX1 Z axis jams when spindle is spinning
    By vmehta211 in forum Benchtop Machines
    Last Post: 06-25-2013, 02:00 PM
  4. How many rpm's is this spindle spinning?
    By Apples in forum Uncategorised MetalWorking Machines
    Last Post: 03-14-2008, 08:40 PM
  5. Spinning a Bridgeport Spindle to 5-6K??
    By snakebit95 in forum Bridgeport / Hardinge Mills
    Last Post: 02-08-2006, 11:08 PM
