603,924 active members*
2,384 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Spindle starts when I exit Mach 4
Results 1 to 5 of 5
    Nov 2016
    5
    Any help would be appreciated here.
    I'm running an ESS Smoothstepper and a C11GS BOB with Mach 4 and Windows 10.
    I just hooked up a Huanyang VFD to my C11GS BOB. I have it working and controllable (for lack of a better word).
    Anyhow the problem that I am having is that when I start my system the relays go active until Mach 4 is running. This causes the spindle to run. This also happens upon exiting Mach 4, the relays go high again and the spindle runs
    I'm convinced that the issue is in the C11GS BOB since no software is running upon start up when the relays get activated.
    Any ideas other than changing the order that I turn things on and off would be greatly appreciated.
    Thanks.
    Doug
    Apr 2004
    5951
    Re: Spindle starts when I exit Mach 4
    Have you tried shutting down the router and VFD before exiting Mach4?
    Andrew Werby
    Website
    Nov 2016
    5
    Quote Originally Posted by awerby View Post
    No, but I'm sure that your suggestion would work since there would be no power to them.
    I am hoping that there is another solution that would cause the relays to not activate on exiting.
    I destroyed my touch probe wire after this happened to me. It's a pretty unacceptable offense in my opinion. I leave my VFD on because it's wire directly into 220 via my breaker box. I gave up on Mach 4 and now run Mach 3 and UCCNC now. I was on ESS and Windows 7 but a different BOB. It also happened once with Mach 4 idle. I've never had this issue with Mach 3 or UCCNC.
    Jun 2011
    692
    Sounds like the logic of the relays is backwards. Are there NO and NC terminals on the relays you're using? Try using the other one (and you'll need to reverse the logic in Mach as well.)
  1. Replies: 26
    Last Post: 04-17-2020, 07:06 PM
  2. Turning on my vac unit when spindle starts up.
    By caseyjaybenson in forum Mach Software (ArtSoft software)
    Last Post: 05-21-2017, 09:24 PM
  3. Spindle stops/starts reversed
    By EagleAD in forum Spindles / VFD
    Last Post: 01-26-2017, 09:30 PM
  4. Alarm Error when spindle starts.
    By mori.seiki.user in forum Mori Seiki lathes
    Last Post: 04-22-2012, 09:07 PM
  5. Spindle starts in windows explorer
    By cut2spec in forum Benchtop Machines
    Last Post: 02-27-2007, 01:49 AM
