588,211 active members*
3,920 visitors online*
Results 1 to 4 of 4
    May 2015
    6
    Spindle and VFD recommendation
    I am new to this forum.
    I have been doing hobby cnc wood working for a couple of years. I work with hardwoods. My longest carves are about 3 hours.
    I am ready to upgrade from a router to a spindle and VFD. I am looking for a recommendation on make, model, horse power, water vs air......
    I know to stay away from Chinese stuff. I am hoping to spend less than $500 on both, if that is even possible.
    Thanks in advance for the advise.
    texasinmi
    Mar 2003
    35538
    Re: Spindle and VFD recommendation
    What kind of machine is this going on, and what will you be doing with it? How deep and fast do you want to cut?
    No, not really. Spindles not made in China tend to start at around $700. VFD 's would start at $250-$300.
    You can get a chinese 2.2Kw spindle and a good VFD for around $500, which is what a lot of people do.
    Or get a Chinese spindle and FVD package for around $350.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2015
    6
    It is going on a Shark cnc. Not too deep, 1-2 inches, and will slow down to improve details.
    What VFD do people put with the Chinese spindle? Is there a Chinese spindle better than others.
    If I went with a Chinese spindle, I would probably change out the bearings, the apparent weakest area. What bearings would you recommend?
    texasinmi
    Mar 2003
    35538
    For a shark, a 1.5Kw would be more than enough, but limited to bits with a 1/4" shank (or smaller).
    Most people buy a kit like this one:
    1 5KW Water Cooled Spindle Motor 1 5KW VFD COOLE Motor Milling High Speed Great | eBay
    Yes, some spindles are better than others. But if buying from China, it's very difficult to know what you'll be getting.
    One way to know what you're getting is to buy from a reseller that tests and guarantees the spindles, like www.ugracncn.com But you'll pay about 50% more.
    Unless you get a spindle with defective bearings, there's no reason to change them. The main difference between the chinese bearings and good spindle bearings will be how long they last. And good spindle bearings will cost much more than the spindle.
    Gerry
  1. Spindle+VDF recommendation for long jobs cutting 18mm Plywood below €1000
    By javito in forum DIY CNC Router Table Machines
    Last Post: 05-17-2013, 10:27 AM
  2. Chinese Spindle Recommendation
    By Rob K in forum DIY CNC Router Table Machines
    Last Post: 12-28-2012, 06:17 PM
  3. Looking for spindle recommendation for carving foams
    By creaturemaker in forum Maintenance DIY Discussion
    Last Post: 03-28-2012, 09:15 PM
  4. spindle and VFD recommendation
    By telah in forum DIY CNC Router Table Machines
    Last Post: 07-04-2011, 02:55 PM
  5. VFD recommendation
    By TheGreenMachine in forum Phase Converters
    Last Post: 01-17-2010, 02:51 AM
