588,206 active members*
4,118 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Videos > Spindle water cooling system
Results 1 to 5 of 5
    Jun 2009
    12
    I wanna show my solution for the water spindle, it's working so good.
    http://youtu.be/Qy_ja34B8ng
    At 35 degrees the fans and LED's switch on, at 33.9 off.
    I couldn't find so many information about this so I wanna share my solution.
    Juan
    May 2012
    18
    Great looking setup for spindle chiller.
    Juan,
    Your solution is not only great looking it also looks to perform as designed.
    Can you share build directions and sources of supply, schematics etc.
    I have a Syil X5 Speedmaster, with a 24K watercooled spindle, I just acquired and need to replace the spindle shiller pump. I dont like the current setup and would like to make an alternate solution independent of the Syil control.
    Any info would be appreciated.
    Thanks,
    Mattster1
    Jun 2009
    12
    I'm using the XSPC Rasa 750 kit, I bought it here:
    XSPC Rasa 750 RS360 Universal CPU / Triple Radiator Water Cooling Kit w/ Free Kill Coil! (ETA - mid-June) - FrozenCPU.com
    The liquid is the non conductive Feser One:
    Feser One Non Conductive Cooling Fluid - 1000 ml - UV Pink (F1-0007) - FrozenCPU.com
    The temperature controller is this:
    http://www.ebay.es/itm/Automatic-Dig...item6b1e926426
    I bought a few accesories to connect the tubes, a T to put the sensor touching the returning water and a metal box for the temperature controller.
    I bought this too to connect a tube with similar diameter of the spindle barbs
    Koolance 1/4" (6mm) ID G1/4 Threaded Barb w/ Hose Clamp - Single - Black (NZL-V06B-BK) - FrozenCPU.com
    With one liter of liquid is enough but if the circuit is long, buy 2 liters, just in case.
    Juan
    Mar 2010
    Juan,
    How is this system holding up for you? Also, could you share where you purchased the box for the temp controller and how you are powering the fans, pump and temp controller?
    Thanks Dave
    Jun 2009
    12
    My system is working like a charm.
    I bought the box in a small shop in Akihabara, Tokyo. Now I'm living here.
    To power the system I'm using a 12v power supply that I bought in ebay.
  1. WATER COOLING SPINDLE 0-24000 rpm ??? is this possible?
    By luis81 in forum Uncategorised MetalWorking Machines
    Last Post: 02-26-2021, 05:38 PM
  2. Air cooling a water cooled spindle
    By JerryBurks in forum DIY CNC Router Table Machines
    Last Post: 08-24-2011, 01:12 PM
  3. Spindle water cooling 101. The right way.
    By diyengineer in forum Uncategorised MetalWorking Machines
    Last Post: 06-28-2010, 05:20 AM
  4. Replies: 4
    Last Post: 05-06-2010, 08:48 PM
  5. Spindle & Ballscrew cooling system
    By Gerald Sande in forum Fadal
    Last Post: 06-07-2008, 04:16 PM
