587,999 active members*
2,666 visitors online*
Thread: SPOST setup
Results 1 to 4 of 4
    May 2004
    3
    Question SPOST setup
    Can someone help me?
    I have an Spost post for my Mach3 Lathe.
    The only problem is that I've only used Mpost.
    My surfcam.pst file had been changed to just Mposts so I cannot use a different spost and change it to my new one.
    I've looked online and have not found anything.
    Any little direction would help.
    Thanks,
    Cadmanj
    May 2008
    7
    To add a post :
    start , all programs, surfcam (your rev) , surfcam tools , post menue wizard.
    after you add a post (spost) change the name to a new name.
    configure the post in spost configuration (same place)
    May 2004
    3
    I get an error
    CNC_Joseph,
    Thanks for the reply.
    I did what you said and it did add the post to my library.
    When I try to post with it i get an error.System cannot find the specified file.
    Do you have any Ideas? I looked in the Surfcam.PST file.
    It did add the command lines in the lathe folder as expected.
    The wierd thing I found is that it is a lathe post and the command line uses Epostwin not lpostwin.
    When I added the post to the menu I picked Lathe.
    Cadmanj
    May 2007
    71
    1. Copy your SPost file for Mach3 Lathe into the \surfcam\postlib\spost\
    (The file should be UNCL01.Pxx and UNCL01.Fxx)
    2. Use the Postwizard to add a post but choose Lathe.
    3. Look at the SPost at right side and choose the Mach3 Lathe from the list
    next , lathe, next, exit , accept.
  1. TM3 Setup
    By Feckless in forum Torchmate
    Last Post: 03-24-2008, 07:34 PM
  2. 4th axis spost
    By doridori4ag in forum Fadal
    Last Post: 03-13-2008, 06:22 AM
  3. Mpost/Spost Tips and Tricks
    By tnik in forum Surfcam
    Last Post: 12-20-2006, 07:32 PM
  4. Surfcam 5 axis spost
    By babanh in forum Surfcam
    Last Post: 11-20-2006, 03:55 AM
  5. Setup i need help
    By k-linkz in forum Hobbycnc (Products)
    Last Post: 08-07-2005, 02:11 PM
