587,854 active members*
4,474 visitors online*
Results 1 to 8 of 8
Hybrid View
    Jun 2009
    25
    Sprocket Design
    I need to do a drawing of a sprocket for a customer and I'm having a "moment" here (as I haven't had to draw one of these in a long time). Its a sprocket for a bike (without a derailleur). the pitch is 1/2", the roller diameter is 5/16" and the pitch diameter is around 12". I've done a couple of drawings but neither one is correct (based on laying it next to my sons bike). any help would be great.
    Pat @ PDJ Cutting
    Mar 2006
    58
    I ran into this problem a couple years ago. Here's a guide to tell you how to draw them:
    http://www.gizmology.net/sprockets.htm
    Fegenbush
    Sep 2006
    36
    1/2" sprocket dims
    Quote Originally Posted by pdjcutandfab View Post
    Pat @ PDJ Cutting
    This Help? 75 teeth, 12.2667" OD/ 11.9401" PD,
    76 teeth, 12.4258" OD/ 12.0992" PD.
    Cheers, Les.
    Jul 2003
    1220
    Les. Your drawing for the 76 teeth shows the 75 tooth dimensions.
    Sep 2008
    117
    Jun 2009
    25
    Thanks for all of the info, I actually did a version 3 last night and it looks pretty close to what Les did, but i'm going to download that sprocket program and see what results i get from that.
    Thanks again to all
    Pat @ PDJ
    Sep 2009
    313
    Hey Pat, let me know what the number of teeth, pressure angle, pitch, outide diameter, root diameter, root radius, and tooth corner radius and I can send you a cad drawing.
    Sep 2006
    36
    Thumbs up SPROCKETEER PROGRAM
    Thanks again to all
    Pat @ PDJ
    I downloaded it something is not right, no compound radii. OD too large, seating curve too small. Sprockets are quite forgiving it will probably go round!
    Cheers, :cheers: Les.
  1. Require DXF/DWG for 35 tooth sprocket.
    By Kiwi in forum Uncategorised CAD Discussion
    Last Post: 06-16-2009, 08:56 AM
  2. how to make a sprocket?
    By pking321 in forum MetalWork Discussion
    Last Post: 04-23-2009, 05:56 PM
  3. RFQ: Sprocket (closed)
    By mcraig79 in forum Employment Opportunity
    Last Post: 07-03-2007, 12:30 PM
  4. Gear sprocket software
    By PlasmaGuy in forum Mechanical Calculations/Engineering Design
    Last Post: 05-15-2007, 11:27 PM
  5. Sprocket teeth
    By MattMachinist in forum MetalWork Discussion
    Last Post: 04-18-2006, 03:06 AM
