I have been trying to create a tool path for a lathe part for a couple of weeks now and no matter what approach I take, I cannot get Sprutcam to generate a tool path that doesn’t remove excess material from the convex curved section. Based on the part and tool geometry used, I cannot think of any valid reason why it would be impossible for the software to generate a path that would very precisely follow the, yet per the simulation it removes far too much material (up to .012” gouge). I have confirmed that the tool path does indeed take away too much material by actually running the generated tool path and measuring the resulting part. Are there some settings incorrect in my file that could be causing this?
