Originally Posted by
am64
I am pulling my hair out trying to figure out why I am having this problem.
I import a STL file, sew, set CS (G54), enter few operation and run simulation without any issues. I change / add a second CS (G55) add say waterline operation without any issues but when I try to add another operation and I go to select faces or edges for the operation it will randomly highligh / select an edge or surface by itself and will not allow me to select my own surfaces or edges. The only way I can move forward is by exiting sprutcam7 at which time I get the Invalid Pointer Operation massage. Any input is welcomed.
Can you import an iges rather than stl? Try that.
Gerry
Currently using SC7 Build 1.6 Rev. 64105
