603,894 active members*
2,818 visitors online*
IndustryArena Forum > CAM Software > CamBam > Spurious toolpaths - Inkscape to DXF to Cambam to Mach 3 NC to tried & tested table
Results 1 to 4 of 4
    Apr 2006
    could you please help me track down an issue that may be CamBam or mach3 related.
    I have some anomalous results from a machining job (See Photos) that may or may not be related to CamBam.
    For brevity I've outlined the workflow and describe the issue in dot points.
    Workflow;
    Import image of guitar jig plan into Inkscape
    Trace outline of parts with inkscape paths (Splines)
    Export paths to DXF file (Standard inkscape setting (Autocad r14) converts to poly lines a arcs)
    Import DXF file into CamBam
    Join segments in CamBam(CTRL+J)
    Manipulate orientation of splines and duplicate for additional machining operations.
    Configure and save toolpaths using Mach3-Cutviewer post processor as *.nc file.
    Machine on rebuilt router table, tried and tested on other machining jobs.
    Issue;
    You can see in the photos I'm getting a step in some of the machined paths which isn't in the digital toolpath. It isn't on all pieces. It isn't a missed step in my setup as it cuts the path the same in 4 passes and returns to point of origin. It cuts the same on multiple jobs (Three time now)
    The parts are not the same width when they should be.
    Holes are off centre.
    I have recalibrated the machine and done considerable fault finding. I've cut the job out three times with the same result.
    I'm thinking its some sort of arc error or a creep within this 20,000 line machining job.
    I have included the cambam file and NC file in the zip file.
    Any help would be appreciated.
    Regards
    Thomas
    Mar 2003
    35494
    Re: Spurious toolpaths - Inkscape to DXF to Cambam to Mach 3 NC to tried & tested tab
    Looks like a mechanical issue to me. Make sure you don't have any loose couplings.
    The g-code looks fine in Mach3, so it's not a software issue.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2006
    thanks for your reply.
    Why do you think it s mechanical issue?
    Everything is tight but I will check it again.
    It cuts our the same each time.
    Im going to re orient the job and see if I get the same errors on the opposite axis.
    Regards
    Thomas
    Mar 2003
    35494
    Because you don't see it in Mach3.
    Gerry
  1. Mach 3 or Cambam Issue? Diy CNC
    By hobbyhands in forum CamBam
    Last Post: 02-12-2013, 04:05 AM
  2. inkscape to cambam
    By linkintiger in forum CamBam
    Last Post: 09-03-2011, 05:40 PM
  3. Mach 3 is messing up drill toolpaths
    By galaxyman7 in forum Mach Mill
    Last Post: 11-29-2010, 06:00 PM
  4. Chip thinning strategies, trochoidal toolpaths, high-speed machining using Mach 3?
    By 307startup in forum Mach Wizards, Macros, & Addons
    Last Post: 11-14-2010, 08:44 PM
  5. Incorrect dimensions from Cambam to Mach 3
    By corneliusbrown in forum CamBam
    Last Post: 10-05-2010, 01:28 PM
