603,390 active members*
2,859 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Squaring a gantry - without a square?
Results 1 to 4 of 4
    Jan 2011
    There must be a more accurate way to square a gantry then just using a carpenters square and a dial gauge. Anyone with good math intuition have ideas?
    Mar 2003
    35494
    Cut some square blocks and measure the diagonals.
    Or, line them up against a straight edge, and check if the edges are aligned. Flip one over and see if it's still aligned.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    String from the middle of the opposite corners of the gantry to the rails
    I would check it from both ends.
    (An illustration for measuring a fence)
    Also, the 2-4-5 method. A triangle with the sides length 3, 4, and 5 will be a right angle.
    My uncensored views and CNC Router planning: http://reinventingcnc.blogspot.com/
    Oct 2005
    2392
    I've got one of those 2 foot long painted steel carpenters squares, the cheap ones from the hardware store. It is surprisingly good, as good as my engineers squares! I think the big die they used to punch it out was cut on an expensive machine.
    And then I use Ger21's method, cut 2 squares as large as possible and flip one over.
  1. is there an easy way to square a gantry?
    By 15mgtar in forum DIY CNC Router Table Machines
    Last Post: 06-21-2010, 06:40 PM
  2. Squaring the gantry
    By bradbergemann in forum Excitech routers
    Last Post: 01-07-2010, 02:31 PM
  3. Squaring your Gantry, 1530 and similar.
    By Big S in forum Excitech routers
    Last Post: 04-15-2009, 10:23 AM
  4. Method to square a Gantry?
    By Motivator-1 in forum DIY CNC Router Table Machines
    Last Post: 02-20-2007, 02:30 AM
  5. Can someone tlee me how to square me gantry? best way?
    By Apples in forum Waterjet General Topics
    Last Post: 09-25-2005, 02:30 AM
