587,853 active members*
3,590 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Squaring X-Y Axis - Home Sensor adjustment question
    Mar 2005
    109
    Ok. So I dismantled my X and Y v-con rail system to add a bunch more v-con clamps. After I put everything back together, I began the squaring and tramming process as outlined in the CNC Router Parts video.
    After drilling the 4 holes one of my measurements is off about 1/16". The video says to adjust the home sensors to square up X and Y, but it does not mention which sensor or which direction to adjust the sensor.
    Can someone please clear up which sensor needs adjustment based on the measurements I have based on the inserted image?
    Apr 2004
    326
    Re: Squaring X-Y Axis - Home Sensor adjustment question
    Quote Originally Posted by ifeliciano View Post
    See attached image with exaggerated diagrams to show out of squareness and arrow indicating which way to move the proximity sensor on the one side.
    Remember this is similar to squaring a cabinet when you're building it. You use a clamp to "squeeze the long diagonal until they are equal (thank you Norm Abrams!).
    Mar 2005
    109
    Cool, thanks for that. Got it DNO!
  1. Proximity switch mounting (home sensor)
    By joel0407 in forum DIY CNC Router Table Machines
    Last Post: 07-05-2017, 12:07 PM
  2. Using hall effect sensor as home switch in middle of axis
    By musicworld1 in forum DIY CNC Router Table Machines
    Last Post: 10-02-2016, 01:21 PM
  3. Turret proximity sensor adjustment
    By MichaelHenry in forum Tormach Slant Lathe
    Last Post: 06-06-2016, 12:24 AM
  4. Proximity sensor or home/limits?
    By kevincnc in forum DIY CNC Router Table Machines
    Last Post: 01-18-2013, 05:43 PM
  5. Replies: 2
    Last Post: 12-08-2011, 02:09 AM
