588,058 active members*
5,084 visitors online*
Thread: SRAM Backup
    Dec 2007
    SRAM Backup
    Hi all
    Can any one tell me how to take SRAM backup or all backups i need to take on fanuc 18i
    Dec 2006
    84
    Power off the control(just control not the whole machine).
    Press the far right arrow key and the key immediately to it's left and continue to hold as you power on the control.(Buttons directly underneath the screen)
    A selection screen will appear. Press the button corresponding to "Down" until you get to SRAM and press the select key. A new screen will appear.
    Scroll to "CNC--->Memory Card"(should be highlighted as soon as the screen opens) and press Select. A confirmation message will appear "Are you sure?" Press "Yes" or "No".
    Once the data is loaded to the Memory card you will be asked to press the "Select" key. Then press the button corresponding to "Down" until you highlight "END". Press "Select".
    Once you press select you will be taken to the main screen, again scroll down to end and press select. The control will boot up as usual.
    Dec 2007
    Thank you
  1. Replies: 4
    Last Post: 07-12-2012, 08:34 AM
  2. Do you use SEND ALL for backup?
    By gar in forum Haas Mills
    Last Post: 06-28-2007, 02:19 PM
  3. Ghost HD backup
    By OLD_Newbie in forum CNC Machine Related Electronics
    Last Post: 06-09-2007, 01:28 PM
  4. Download to SRAM
    By Bluesman in forum Fanuc
    Last Post: 02-16-2007, 05:49 PM
  5. Backup Script..
    By Rekd in forum Mastercam
    Last Post: 09-11-2003, 03:34 PM
