587,480 active members*
3,413 visitors online*
Thread: stalling ???
Results 1 to 6 of 6
    Sep 2011
    22
    stalling ???
    i just reduced my drive to 1:3 and now my motors stall. prior to this i was running them direct ....... any help to why would be greatly appreciated
    Nov 2009
    159
    If your using smaller motors and this happens your accel rate may be too high.
    Now featuring Plasmaland online
    Jun 2009
    226
    Sounds like the motors are running too fast. With the 3:1 reduction, they will have to turn 3 times as fast to get the same cut speed. Try reducing the cut speed and see if it helps.
    Willy
    Jul 2005
    2415
    You must:
    Reset your Steps per unit (motor tuning) Re-run your calibration tests to make sure you are moving 1" for a 1" command in MACH.
    Lower your Velocity setting to 500 - 600 IPM (depends on the motors and pinion specs)
    Run your acceleration lower UNTIL you get the other tuning done then bring it up 5 IPS/sec per time.
    The goal with belt reduction is to trade the speed you don't need for torque and resolution you do need,
    Physically the motors will only spin just so fast (PRM) If you leave them at some high velocity (like 1000 IPM ) then add a belt reduction you would have to spin the motor at about 1000 RPM to get that spped and it stalls (No can do)
    Sep 2011
    22
    thanks guys for the repleys. i increased my v-ref to motors and it seemed to help. i can get about 350 IPM ok. but prior to the reduction i was getting like 750+ IPM. also now 1 rev=1 inch. my motors must suck. whats the max rpm these things will spin?
    Jul 2005
    2415
    Motor RPM is totally dependent on:
    motor drive voltage. (24V RPM is 1/2 of 48V RPM given the same motors)
    motor drivers
    motor inductance (to an extent)
    kernal speed of MACH3 (limits max steps per second)
  1. X2, Stalling motor
    By nateman_doo in forum Benchtop Machines
    Last Post: 01-04-2011, 11:10 PM
  2. HF motor stalling out
    By surrealism in forum Mini Lathe
    Last Post: 07-01-2010, 06:08 AM
  3. HAAS TL-3W stalling
    By ghafer in forum Haas Lathes
    Last Post: 07-07-2009, 05:42 PM
  4. Stalling Steppers
    By mrscheider in forum Benchtop Machines
    Last Post: 01-30-2008, 09:10 PM
  5. motor stalling
    By planescott in forum Mechanical Calculations/Engineering Design
    Last Post: 05-06-2006, 03:50 AM
