603,965 active members*
2,468 visitors online*
    Nov 2005
    5
    stalling on Keling setup
    I feel like I've tried every possible combination of settings to get my Keling setup working, and I still get frequent stalling and grinding.
    I've got:
    C10 Parallel board
    3 KL4030 drivers
    3 KL23H2100-30-4B (382 oz) motors
    KL-320-36 power supply
    I've tried both setting each axis to 800 SPI with the microstepping set to 1, or 6400 SPI with microstepping set to 1/8. I've got the current set to 3.0. I've tried every possible combination of direction and step pulse. I get an almost passable accuracy when I set the speed really low (one inch per minute), but it still grinds roughly every 1/3 of a turn. At higher speeds, like 20 inches per minute, it will have longer smooth stretches, but the grinding and stalling will also last longer when it occurs. If I try a speed like 60, it stalls for almost the whole cycle.
    This grinding and stalling occurs regardless of whether my motors are hooked up to the lead screws, or just running on their own. It happens with all 3 motors.
    In trying to diagnose the problem, I've noticed that when I send a G0 command in Mach3 and then watch on the diagnostics screen, the buffer value is typically at 3%, but will shoot up to about 12% when the stalling occurs. Unfortunately, I don't have enough knowledge to understand what all of this means, and what I can do to fix it. Any suggestions would be greatly appreciated.
    Jun 2007
    150
    um, I think 382oz motors are rated at 2.5 amps?
    the higher current setting would give the wrong 'chopping' effect, if it has any.
    i think the 1/8 or 1/10 stepping would smooth it a little, less amps, more voltage, the motor tuning in mach 3 usually likes .3 microsecond points on the motortuning (.3off,.3on,.3off).
    You could spend a whole evening trying the settings with the motor on a bench, you'll get it soon enough.
    Feb 2007
    4550
    Post
    [nomedia="http://www.youtube.com/watch?v=8Am69_F93yA"]YouTube- 65 ipm[/nomedia]
    Do a search on stepper dampers.
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  1. Keling 5056 driver setup
    By alexccmeister in forum Automation Technology Products
    Last Post: 04-20-2011, 04:28 AM
  2. oh no only my y axis keeps stalling
    By stk2008 in forum CNC Machine Related Electronics
    Last Post: 09-25-2009, 11:09 PM
  3. stalling problem
    By cxixer in forum Stepper Motors / Drives
    Last Post: 10-27-2008, 03:47 PM
  4. Stalling Steppers
    By mrscheider in forum Benchtop Machines
    Last Post: 01-30-2008, 09:10 PM
  5. motor stalling
    By planescott in forum Mechanical Calculations/Engineering Design
    Last Post: 05-06-2006, 03:50 AM
