603,355 active members*
3,786 visitors online*
Thread: Star VNC 32
    Dec 2009
    Star VNC 32
    Hi.
    We have a 1986 Star Vnc 32. We were changing a 3/8 bar and didn't close the collet and hit start. The material was pushed up a few inches and the monitor and panel went out. It was if the estop was tripped. My partner had a friend look at it but they couldn't figure out what is keeping it from coming back. They said it's like the reset button is stuck. The button wasn't pushed when this happened either.
    I can post more info if someone has any thoughts on this.
    Thanks,
    Michelle
    Mar 2008
    443
    Start by disconnecting the main power supply switch. Open the electrical panel door and press every reset button, heater and circuit breaker you can find, then check every fuse. There's got to be an overload tripped in there somewhere.
  1. Star VNC-12
    By tech18* in forum Uncategorised MetalWorking Machines
    Last Post: 11-22-2009, 01:36 PM
  2. Star SR20
    By jrob69 in forum Employment Opportunity
    Last Post: 08-21-2008, 05:52 AM
  3. Help with Star SR20RII (Please)
    By mrtedzr in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-27-2007, 08:12 PM
  4. Star
    By TZ250 in forum Dolphin CAD/CAM
    Last Post: 08-27-2007, 01:09 PM
  5. Need Star in .dxf
    By rcazwillis in forum Uncategorised CAM Discussion
    Last Post: 12-29-2005, 12:16 PM
