![Quote](images/misc/quote_icon.png)
Originally Posted by
Falcon69
Gerry,
Yes, I am using 25mm on the Y-Axis and 20mm on the X-Axis.
Okay, I can plan on getting it machined. Shouldn't be that much cash to get it flattened. I should probably change the design just a little to add for the machining. How much, maybe .005 added to it? Like, say, if I have it drawn for 24mm (.945") spacing now between bearing and rail, I should make it .94" ? Or, seeing that the mounting surface is 3/8" thick, maybe just leave it the way it is, since there's plenty of material to take away?
Louie,
I checked on that. The machine leaves .001" kerf. I've allowed for that. If the tab is 1/4"x3/4", I've allowed myself 1/256" around it for the slot, that's .004" around the tabs for spacing for kerfs, etc.
Have you seen the Logo on another machine? I haven't seen it. I was just messing around with the splining tool on SolidWorks one day and just came up with the design.
The problem with CNCLaser, is it heat treats the material, hardening it, so I've been told. That will make it a little tougher to Tap the holes for threading. But you are right, for the thickness I am working with, it is cheaper. If my material had been like 4 inches thick, then Water-Jet would be cheaper. I'll check into it more. Does Laser leave a Kerf as well? The material is 1/4", 3/8" and 1/2" (1/2 inch for the router mounts) mild steel.
VTX,
Thanks!
I was also thinking about getting everything Powder Coated as well after it's been welded up and sanded. How much do you think I need to add to the bearing surfaces to allow for the thickness of the powder coating? I don't want the bearings to be too tight. I'd have to do this to the Z-Axis and the Y-Axis, as the X-axis just floats off the rails.
