I have decided "to take the plung" haha and build my own router table. And have some ummm.... Lots of questions. I will give you a bit of background and what I would like the machine to do. I am a PLC automation programmer/designer in the industrial field and been around control systems for a few years. So electronics and building stuff is what I do for a living so Im not totally blind going into this. I have just learned over time most things are possible just do some research before you start. I have almost "3 times" now purchased the v90 from probotix but just have been turned off buy the material it is made of and doesnt meet the size I want.
I want to use this machine to mainly cut out foam for inside gun cases, camera cases, etc. But dont want to be limited to just that. Wood, plastics
and other stuff would be nice (mainly for gun grips for shooting range buddies).This will be just a start into a business for me NOT going to quit my day job anytime soon but want to look towards the future maybe move up later to a plasma table.
I do have access to a few machine shops that I can have my parts cut with either water jet or laser. So the precision cut parts are not an issue. I can draw and have access to autocad at work and am learning to draw in 3d as I go. I have used an older zenotech engraving machine at work for years converting tags in cad for control panels to the "old dinosaur" and cutting them out but it just is not big enough to do what I want to do.
So here I go with the loads of questions.
Heres what I had in mind for motors and drives.
Can I do better for the price
Kit Includes:$359
3x ProboStep VX Uni-Polar Stepper Motor Driver
2x HT23-280-8 280ozin Stepper Motor (X- & Y-Axis)
1x HT23-400-8 400ozin Stepper Motor (Z-Axis)
PBX-2 Parallel Port Breakout Board
24Volt 6.5Amp Switching Power Supply
6ft. DB25 Male-to-Male Cable
3x 4" IDC Cable 10-pin
I dont have a desktop pc with Parallel port So I figured I need this.
Or can I use an usb to Parallel adapter off the shelf from elctronics store?
PBX-USB CNC Controller $99.95
4 axis USB CNC controller
USB (V2.x) from PC/Laptop running Windows XP, Vista or Windows 7 (32 bit or 64 bit)
3 digital outputs (flood, mist, spindle)
25 KHz maximum step frequency
12us minimum pulse width
Buffered I/O for maximum performance
Two manual jog input keys per axis (8 total)
Two limit switches for X,Y, Z (6 total)
Jog Pendant Interface
Relay Board Interface
I2C Interface
E-Stop Loop
I had seen a video with a probe mounted on the router doing a 2.5d profile of a piece mounted to the spoil board. Is this hard? expensive? to add into the system. Is this the best way to get a profile for an object?
Any suggestions for a probe?
I am planning in building an approx 2x4 machine with 5 inches of z axis.
What size guide rods for the 4ft distance?
What size guide rods for the 2ft distance?
What size guide rods for the z axis?
I had planned on using McMaster Carr for most of the mechanical parts.
Is there somewhere better priced?
Is there somewhere better I should be shopping for electronics devices?
Which router?
I really appreciate any and all help you can give me. I am really looking forward to getting started.
