The trucks should be accurate. Mine are 30mm center to center in the direction parallel to the rail, and 32mm across.
The rail holes are usually a bit inaccurate as they appear to be drilled by hand.
You will probably want to use something other than MDF for that flat plate. It gradually compresses and your screws will before loose over time.
