603,385 active members*
2,631 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Starting from Zero - What do I need?
    May 2007
    On my wall I have a clock. It has a self-contained (stepper?) motor that turns at a set, accurate rate of speed day after day, month after month. I do have the abilty to make a fine speed adjustment on the back but have never needed it.
    I want a larger, more powerful motor that, in effect, acts the same way. I want it to turn at a set, accurate, pre-determined design speed. The ability to fine adjust the speed would be very useful but not required if it is difficult to achive.
    I have very limited knowledge of electronics. I have been frustrated with trying to use a stepper motor for this use. To use a stepper motor, I also seem to have to buy a controller and driver and connect the motor to a laptop computer loaded with a software program. Every setup I have found will do a thousand times more than I need. I am not trying to power a robot or controling a NC machine. I only want the motor to spin at a pre-determined speed.
    Is it possible to use a stepper motor like a self-contained motor in a common clock without an expensive driver, controller, computer and software? How do I control the speed of a stepper motor as a clock controls its speed? What is the least I need to accomplish this?
    Thanks, Ken Brown
    Feb 2006
    1187
    A dc motor and the appropiate speed controller.
    Here try this link http://www.surpluscenter.com/electri...tname=electric
    Surplus Center - Electric Motors, Gearmotors, Relays, Toggle Switches
    May 2007
    Quote Originally Posted by ZipSnipe View Post
    What is "a appropiate speed controller"? Again, the clock on my wall does not use a external controller yet turns at a constant speed by using quartz. Is it not possible to use a motor and a simple circuit to do the same. How do I do this or to whom do I go to for the diagram and parts. I want to keep the design as simple as possible to accomplish the one job it is needed to do.
    KB
  1. Starting out in UK
    By plexer in forum DIY CNC Router Table Machines
    Last Post: 09-25-2007, 10:10 AM
  2. Need help starting
    By agenso585 in forum Diemaking / Diecutting
    Last Post: 02-05-2007, 08:56 PM
  3. Just Starting Out and Need Help
    By bnoji in forum MetalWork Discussion
    Last Post: 01-01-2007, 07:27 PM
  4. Just starting out
    By BawFlinger in forum OneCNC
    Last Post: 10-18-2006, 09:13 AM
  5. Starting from sub-zero
    By eternauta3k in forum Commercial CNC Wood Routers
    Last Post: 01-24-2006, 03:55 PM
