587,999 active members*
5,276 visitors online*
Results 1 to 6 of 6
    Feb 2005
    53
    Stauff Clamps
    Has anybody experimented with Stauff clamps as linear bearing housings?
    They are a green 2 piece plastic clamp with a metal base and top. The base has 2 tapped holes.
    I am using 2 on each side of each axis for a 3 axis machine.
    Just wondering if anybody else is using the same.
    Prboz
    More information here http://www.stauff.com/Stauff/china/english/Clamps.asp
    Dec 2005
    132
    There are aluminum clamps as well, think they are used for hydraulic systems.
    Aug 2009
    4
    Stauff
    Do u have any pictures of ur machine?
    I am thinking about using stauff gr3 clamps filled with grease outside a 25mm aliminum pipe..
    Kim
    Feb 2005
    53
    Some Pictures I have.
    I Stauff Clamp actually holds a linear bearing.
    :rainfro:Prboz
    Aug 2009
    4
    Linear bearing
    What kind of steel rod and linear bearing are u using. Stauff clamps are really easy to use.... Do you have more pictures aswell? It looks pretty impressive.. I have just made some corner brackets and some feet. Gonna start with the linear bearings now..
    Feb 2005
    53
    The Rods are just bright Mild steel and the linear bearings I bought off Ebay.
    It is only fairly light duty as I cut Radio Controlled Aeroplane parts for Scratch built planes.
    I use a dremel as the router and bits up to 1/4"
    Have attached 2 more images.
    Regards
    Prboz
