I have a ClearVue mini cyclone connected to my dust collector that seems to work well. Unfortunately, the 5 gallon bucket that is used with the cyclone isn't so great. Last weekend the seal on the bucket failed. In addition to losing suction, the dust went into my vacuum nearly filling my filter bag. Before this failure, I thought that too much dust was getting to the vacuum so I think things have not been right for a while. I repaired the seal but it looks like another seal failure is only a matter of time.
It seems to me that a small steel barrel would work well. I was inspired by the 10 gallon barrel that is available from Oneida. I found a 5 gallon barrel on Amazon which seems to be the right size to fit into my machine. Anyone have comments? Can I do better? Is there a better solution?
Here's a link to the barrel from Amazon: [ame="http://www.amazon.com/SKOLNIK-Carbon-Steel-gallons-0-9mm/dp/B006P5RJ4E/ref=sr_1_13?ie=UTF8&qid=1343159704&sr=8-13&keywords=5+gallon+steel+drum"]SKOLNIK Carbon Steel Open Head Drum, 5 gallons, Bolt Ring, 0.9mm Body Gauge (Pack of 1): Amazon.com: Industrial & Scientific[/ame]
Here's a photo:
