587,830 active members*
2,643 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > step and direction control for opto22 servo drive
Results 1 to 5 of 5
Hybrid View
    May 2006
    12
    Hi Folks,
    i have been using stepper systems for a while...
    I recently recieved some surplus linear slides driven with servos...
    the drives require opto 22 digital input (+/-24v)
    are there any products that can convert step and direction (so i can use Mach 3) to opto22...
    If all else fails it looks like i can drive them in analogue mode with
    http://www.skyko.com/products/
    thanks in advance
    andrew
    Dec 2003
    24220
    What is the Opto22 product that you refer to?
    Most of their line is just opto isolators, but they do have a line of controller also, but mainly aimed at I/O devices.
    Al.
    Albert E.
    May 2006
    12
    I may have mis-understood
    The manual "http://www.adept.com/main/KE/DATA/ARCHIVED/SUMMER_03/AdeptMod AdeptMotion User/MMVMEUG.PDF" has a description that refers to digital input/output via Opto-22
    Then talks about the Drive Enable signaling under digital inputs as +/-24v
    so i did a bit of googling and found opto-22 interfaces on Servo cards seem to be 24v..so i put 2 and 2 together...but i may have got an answer that wasnt 4
    It then later talks about Analogue input (Torque Control)...at +/-10v
    Hopefully this helps clarrify the situation
    cheers
    Andrew
    Apr 2006
    10
    Hi Andrew,
    I have been looking to do the same,( I can get my hands on some industial servo
    drives that take a +/- 10v signal ) and have been researching how to convert
    a step and direction signal to drive a servo. You might want to look at this
    http://www.jrkerr.com/icproducts.html
    the pic servo sc chip should do it, with the following circuit added(from the data
    sheet for the chip) I think I will give it a try myself.
    Apr 2006
    10
    I just now looked at the link that Andrew posted, and it appears to be just the thing
    I was looking for, thanks Andrew!
    Jeremiah
